@mnordhoff and @JuergenAuer
Thank you for your help. Can you please verify one more time for me? I just recreated the certs and everything should be good now.
[root@web3 ~]# certbot --apache -d arundelnewsnet.com -d www.arundelnewsnet.com
requested (ref: /etc/letsencrypt/renewal/arundelnewsnet.com.conf)
It contains these names: arundelnewsnet.com
You requested these names for the new certificate: arundelnewsnet.com,
www.arundelnewsnet.com.
certificate?
(E)xpand/Šancel: E
http-01 challenge for arundelnewsnet.com
http-01 challenge for www.arundelnewsnet.com
Waiting for verificationâŚ
Resetting dropped connection: acme-v02.api.letsencrypt.org
Deploying Certificate to VirtualHost /etc/httpd/sites-available/arundelnewsnet.com-le-ssl.conf
new sites, or if youâre confident your site works on HTTPS. You can undo this
change by editing your web serverâs configuration.
Select the appropriate number [1-2] then [enter] (press âcâ to cancel): 2
Redirecting vhost in /etc/httpd/sites-enabled/arundelnewsnet.com.conf to ssl vhost in /etc/httpd/sites-available/arundelnewsnet.com-le-ssl.conf
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://arundelnewsnet.com and
https://www.arundelnewsnet.com
https://www.ssllabs.com/ssltest/analyze.html?d=arundelnewsnet.com
https://www.ssllabs.com/ssltest/analyze.html?d=www.arundelnewsnet.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/arundelnewsnet.com/fullchain.pem
/etc/letsencrypt/live/arundelnewsnet.com/privkey.pem
Your cert will expire on 2019-04-26. To obtain a new or tweaked
with the âcertonlyâ option. To non-interactively renew all of
your certificates, run âcertbot renewâ
Donating to ISRG / Letâs Encrypt: https://letsencrypt.org/donate
