Some problems with duckdns
My domain is: plantseeds.duckdns.org
I ran this command: Running certbot in dry-run mode to test the validity of the domain...
It produced this output: Certbot failed to authenticate some domains (authenticator: standalone). The Certificate Authority reported these problems:
Domain: adguard.plantseeds.duckdns.org
Type: connection
Detail: 209.250.247.242: Fetching http://adguard.plantseeds.duckdns.org/.well-known/acme-challenge/QSr2zEaMYKSqT48v2-KExRf1MNcvmPUa2nGHBt-OeZQ: Timeout during connect (likely firewall problem)
Domain: auth.plantseeds.duckdns.org
Type: connection
Detail: 209.250.247.242: Fetching http://auth.plantseeds.duckdns.org/.well-known/acme-challenge/u6KOLqnNWwewFocPPtYawDEGsdiLA7hd88c8GdTgEAA: Timeout during connect (likely firewall problem)
Domain: plantseeds.duckdns.org
Type: connection
Detail: 209.250.247.242: Fetching http://plantseeds.duckdns.org/.well-known/acme-challenge/xDe5sbpaTL55DWBz0nHEJJ4uB4_ErXUpOFQ8i3-nBVA: Timeout during connect (likely firewall problem)
Domain: wg.plantseeds.duckdns.org
Type: connection
Detail: 209.250.247.242: Fetching http://wg.plantseeds.duckdns.org/.well-known/acme-challenge/sL-TNELvIGXyQBVp1AS3rAnkJNjfRqIENJCpRdvRFC8: Timeout during connect (likely firewall problem)
Requesting a certificate for plantseeds.duckdns.org and 3 more domains
Type: connection
Detail: 209.250.247.242: Fetching http://adguard.plantseeds.duckdns.org/.well-known/acme-challenge/xZCJUJVOOh5-LLQw8wArEF__YpoMWzSx_h4CNBr3k-w: Timeout during connect (likely firewall problem)
Type: connection
Detail: 209.250.247.242: Fetching http://auth.plantseeds.duckdns.org/.well-known/acme-challenge/KAs5rOBh2nxDABmUKRT_m4f8Mfy9REnOzUuUEYoe57g: Timeout during connect (likely firewall problem)
Type: connection
Detail: 209.250.247.242: Fetching http://plantseeds.duckdns.org/.well-known/acme-challenge/Q7_PYb0NX8KZ5tbtETolmG9AzYHMssQL8jOqKI9VYR4: Timeout during connect (likely firewall problem)
Type: connection
Detail: 209.250.247.242: Fetching http://wg.plantseeds.duckdns.org/.well-known/acme-challenge/1bmzBO7sWQOufyvHkCHnHK214QvwAaQS2_ZL55-Uud8: Timeout during connect (likely firewall problem)
My web server is (include version): none
The operating system my web server runs on is (include version): debian 11
My hosting provider, if applicable, is: vultr
It's not a DuckDNS problem, as the hostnames are resolving to the IP address just fine.
The problem is that your webserver isn't accessible using HTTP on port 80. You should check any firewall present (could be on your server and somewhere else e.g. at Vultr) and open port 80 (and 443).
The problem has gone after I enabled 80 port
ufw allow 80
Thanks to Osiris
