Some general advice with invalid response from domain
yamspace.org
certbot --nginx -d yamspace.org
[root@srv ~]# certbot --nginx -d yamspace.org
http-01 challenge for yamspace.org
Waiting for verification…
Challenge failed for domain yamspace.org
   Domain: yamspace.org
   Type:   unauthorized
   Detail: Invalid response from
   http://yamspace.org/.well-known/acme-challenge/gsYDCE7bXWJ0QSXAR2g1fr__pVPIBqsmgH6F0I_2YxA
   [77.235.46.11]: "<html>\r\n<head><title>404 Not
   Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404
   Not Found</h1></center>\r\n<hr><center>"
nginx/1.12.2
CentOS-7
no
certbot 0.36.0
Hey
I hope people dont mind me posting im reletivly new to using lets encrypt and certbot, above is the error I am getting back, I have tried a few things already based on some of the other topics I have read (checked dns etc) but so far no success, I am going to crack on reading some more posts but I thought it would be good to get something posted to try and get some further guidance on how to troubleshoot this problem
cheers
Welcome to this community.
Since you are using Nginx plugin for certbot, could you please share your Nginx confg (virtual hosts) for your domain?
Your redirect doesn’t setup correctly.
When i visit your plain http site, the server redirects me to the “secure” (https) version. But when i visit your plain site with your .well-known folder, it doesn’t redirect.
Also, your Nginx version is not matching. You are saying that your Nginx server is running Nginx 1.12.2, but the actual output is saying that it’s running on Nginx 1.11.6
As a general practice, please try to put a dummy file under your domain and share us the links to that file.
(The file location should be under `/$your domain root folder/.well-known/acme-challenge/’)
Thank you
Good catch, @stevenzhu!
Hi @barundel
looks like you have found a solution.
Now there is a new certificate:
CN=forum.yamspace.org
	31.08.2019
	29.11.2019
expires in 90 days
forum.yamspace.org,
www.yamspace.org, yamspace.org - 3 entries
non-www and www uses that certificate, so both connections are secure. Grade E isn't optimal, but it's good, no critical error.
