[solved] Timeout during connect (likely firewall problem)
My domain is: snipsserver.spacetechnology.net
I ran this command: certbot -v renew --dry-run
Processing /etc/letsencrypt/renewal/snipsserver.spacetechnology.net.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for snipsserver.spacetechnology.net and snips.spacetechnology.net
http-01 challenge for snips.spacetechnology.net
http-01 challenge for snipsserver.spacetechnology.net
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain snips.spacetechnology.net
Challenge failed for domain snipsserver.spacetechnology.net
  Domain: snips.spacetechnology.net
  Type:   connection
  Detail: 91.64.50.159: Fetching http://snips.spacetechnology.net/.well-known/acme-challenge/CkUCTsSbQ3ic56B83caCl3KPkOD7PdbnhJ1thnYCvgg: Timeout during connect (likely firewall problem)
  Domain: snipsserver.spacetechnology.net
  Type:   connection
  Detail: 91.64.50.159: Fetching http://snipsserver.spacetechnology.net/.well-known/acme-challenge/lYJw0bLHDFxOE_P35kiC5nOe-5KWDVqLS3BmttBi4q4: Timeout during connect (likely firewall problem)
Failed to renew certificate snipsserver.spacetechnology.net with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
  /etc/letsencrypt/live/snipsserver.spacetechnology.net/fullchain.pem (failure)
My web server is (include version): Apache/2.4.54
The operating system my web server runs on is (include version): Debian GNU/Linux bookworm/sid
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
I can Access my Website from outside of my LAN.
The Apache access.log show me the connects from the Let's encrypt Servers with Status 200:
3.139.90.174 - - [09/Dec/2022:00:04:06 +0100] "GET /.well-known/acme-challenge/CkUCTsSbQ3ic56B83caCl3KPkOD7PdbnhJ1thnYCvgg HTTP/1.1" 200 310 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
35.90.230.200 - - [09/Dec/2022:00:04:06 +0100] "GET /.well-known/acme-challenge/CkUCTsSbQ3ic56B83caCl3KPkOD7PdbnhJ1thnYCvgg HTTP/1.1" 200 310 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.139.90.174 - - [09/Dec/2022:00:04:06 +0100] "GET /.well-known/acme-challenge/lYJw0bLHDFxOE_P35kiC5nOe-5KWDVqLS3BmttBi4q4 HTTP/1.1" 200 310 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
35.90.230.200 - - [09/Dec/2022:00:04:06 +0100] "GET /.well-known/acme-challenge/lYJw0bLHDFxOE_P35kiC5nOe-5KWDVqLS3BmttBi4q4 HTTP/1.1" 200 310 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
snipsserver.spacetechnology.net - Make your website better - DNS, redirects, mixed content, certificates can also access my Page.
I don't understand where the Problem is.
Do you have some kind of geo-IP blocking going on? Or a firewall rule set you got from the internet?
I can access your server from the US, but not from my home connection in Australia.
You should see 3 different IPs. One server is being blocked (probably 23.178.112.107).
Thanks for you help, yes it was a geo-IP Filter. :+1:
