I have problems renewing my certificate.
Domain: css.polijeux.com
Type: connection
Detail: Connection refused
The domains does not have AAAA entry.
certbot version: 0.18.1
I am running: certbot-auto renew
What can i do?
Thanks
Type: connection
What can i do?
Thanks
Please fill out all fields on the form presented. How did you attempt to renew this? Please give the full output of your attempts. Also, how did you issue this certificate initially?
All this tells us is that your server is refusing a connection. Perhaps you have a misconfigured firewall?
Hi Jared.
From my server I run: certbot-auto renew
Type: connection
I executed in my server: certbot-auto --apache certonly
I don’t have a misconfigured firewall. I can access the domain by wget or browser.
Thanks
Marcos.
@mcanan install python2.7
Thanks. That solved it.
