Hello, I don’t know if there is a french section for this forum, so I post here.
My problem is that I wanted to renew my letsencrypt certificat on my server (yunohot) by following a tutorial(both in English and French).
But the command line to renew did’nt work and I got something like this:
Updating letsencrypt and virtual environment dependencies......Command "/root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-jtKEQ5/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-fWg4Ya-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/pip-build-jtKEQ5/cryptography
So I tried to re-install letsencrypt and a new certificat (by following still the same tutorial as much as I could), but my nginx didn’t like it and tell me this:
nginx: [emerg] duplicate location "/.well-known/acme-challenge" in /etc/nginx/conf.d/NdD.tld.conf:9 nginx: configuration file /etc/nginx/nginx.conf test failed
I finally reboot my server, and I can’t access my website, my certificate is over, but I can still access by ssh.
I don’t know how to resolv this problem =/
Librement vôtre.
I also asked on Yunohost forum, and my server works well! (it’s there)
