i am trying to renew my certs by running './letsencrypt-auto certonly --standalone' and see the following error:
Command "/root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;file='/tmp/pip-build-Lvxrcr/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-p746mT-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/pip-build-Lvxrcr/cryptography
i use digital ocean 512MB with ubuntu 14.04 python version 2.7.6. any clues?
Also, I tried the advice here Failed with "/tmp/pip-build-NISEZn/cryptography" - #2 by ngld but it didn't work.
here is the output of root@do:/opt/letsencrypt# ./letsencrypt-auto -v -h:
Updating letsencrypt and virtual environment dependencies...
Requirement already up-to-date: setuptools in /root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: pip in /root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: pyopenssl in /root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: ndg-httpsclient in /root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: pyasn1 in /root/.local/share/letsencrypt/lib/python2.7/site-packages
Requirement already up-to-date: six>=1.5.2 in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from pyopenssl)
Collecting cryptography>=0.7 (from pyopenssl)
Using cached cryptography-1.2.2.tar.gz
Requirement already up-to-date: idna>=2.0 in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->pyopenssl)
Requirement already up-to-date: setuptools>=1.0 in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->pyopenssl)
Requirement already up-to-date: enum34 in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->pyopenssl)
Requirement already up-to-date: ipaddress in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->pyopenssl)
Requirement already up-to-date: cffi>=1.4.1 in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from cryptography>=0.7->pyopenssl)
Requirement already up-to-date: pycparser in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from cffi>=1.4.1->cryptography>=0.7->pyopenssl)
Installing collected packages: cryptography
Found existing installation: cryptography 1.2.1
Uninstalling cryptography-1.2.1:
Successfully uninstalled cryptography-1.2.1
Running setup.py install for cryptography ... error [80/846]
Complete output from command /root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;file='/tmp/pip-build-PWWeBt/cryptography/setup.py';exec(comp
ile(getattr(tokenize, 'open', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-RhxI8g-record/install-record.txt --single-version-exte$
nally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography:
running install
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.7
creating build/lib.linux-x86_64-2.7/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-x86_64-2.7/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-x86_64-2.7/cryptography
copying src/cryptography/init.py -> build/lib.linux-x86_64-2.7/cryptography
copying src/cryptography/utils.py -> build/lib.linux-x86_64-2.7/cryptography
copying src/cryptography/about.py -> build/lib.linux-x86_64-2.7/cryptography
creating build/lib.linux-x86_64-2.7/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-x86_64-2.7/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-x86_64-2.7/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-x86_64-2.7/cryptography/x509
copying src/cryptography/x509/init.py -> build/lib.linux-x86_64-2.7/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-x86_64-2.7/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-x86_64-2.7/cryptography/x509
creating build/lib.linux-x86_64-2.7/cryptography/hazmat
copying src/cryptography/hazmat/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/multibackend.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/serialization.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/openssl
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/commoncrypto
copying src/cryptography/hazmat/bindings/commoncrypto/binding.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/commoncrypto
copying src/cryptography/hazmat/bindings/commoncrypto/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/bindings/commoncrypto
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/openssl
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/commoncrypto
copying src/cryptography/hazmat/backends/commoncrypto/hashes.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/commoncrypto
copying src/cryptography/hazmat/backends/commoncrypto/hmac.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/commoncrypto
copying src/cryptography/hazmat/backends/commoncrypto/ciphers.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/commoncrypto
copying src/cryptography/hazmat/backends/commoncrypto/backend.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/commoncrypto
copying src/cryptography/hazmat/backends/commoncrypto/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/backends/commoncrypto
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/kdf
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/interfaces
copying src/cryptography/hazmat/primitives/interfaces/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/interfaces
creating build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/init.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-x86_64-2.7/cryptography/hazmat/primitives/twofactor
running egg_info
writing requirements to src/cryptography.egg-info/requires.txt
writing src/cryptography.egg-info/PKG-INFO
writing top-level names to src/cryptography.egg-info/top_level.txt
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing entry points to src/cryptography.egg-info/entry_points.txt
warning: manifest_maker: standard file '-c' not foundreading manifest file 'src/cryptography.egg-info/SOURCES.txt' reading manifest template 'MANIFEST.in' no previously-included directories found matching 'docs/_build' warning: no previously-included files matching '*' found under directory 'vectors' writing manifest file 'src/cryptography.egg-info/SOURCES.txt' running build_ext generating cffi module 'build/temp.linux-x86_64-2.7/_padding.c' creating build/temp.linux-x86_64-2.7 generating cffi module 'build/temp.linux-x86_64-2.7/_constant_time.c' generating cffi module 'build/temp.linux-x86_64-2.7/_openssl.c' building '_openssl' extension creating build/temp.linux-x86_64-2.7/build creating build/temp.linux-x86_64-2.7/build/temp.linux-x86_64-2.7 x86_64-linux-gnu-gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c build/temp.linux-x86_64-2.7/_openssl.c-o build/temp.linux-x86_64-2.7/build/temp.linux-x86_64-2.7/_openssl.o
x86_64-linux-gnu-gcc: internal compiler error: Killed (program cc1)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.8/README.Bugs> for instructions.
error: command 'x86_64-linux-gnu-gcc' failed with exit status 4----------------------------------------Rolling back uninstall of cryptography
Command "/root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;file='/tmp/pip-build-PWWeBt/cryptography/setup.py';exec(compile(getattr(tokenize, 'o
pen', open)(file).read().replace('\r\n', '\n'), file, 'exec'))" install --record /tmp/pip-RhxI8g-record/install-record.txt --single-version-externally-managed --compile
--install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/pip-build-PWWeBt/cryptography
