Fedora 15 - suddenly getting errors when trying to renew using certbot-auto
Out of nowhere I am suddenly not able to update my certificates any more. It runs on an old Fedora 15 server and that is probably part of the problem? Please see my filled in information below:
My domain is: gr8.nu
I ran this command: certbot-auto renew
Bootstrapping dependencies for RedHat-based OSes… (you can skip this with --no-bootstrap)
yum is /usr/bin/yum
Loaded plugins: langpacks, presto, refresh-packagekit
http://dl.google.com/linux/chrome/rpm/stable/i386/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found : http://dl.google.com/linux/chrome/rpm/stable/i386/repodata/repomd.xml
Trying other mirror.
Setting up Install Process
Package gcc-4.6.3-2.fc15.i686 already installed and latest version
Package augeas-libs-0.10.0-3.fc15.i686 already installed and latest version
Package openssl-1.0.0j-1.fc15.i686 already installed and latest version
Package openssl-devel-1.0.0j-1.fc15.i686 already installed and latest version
Package libffi-devel-3.0.10-1.fc15.i686 already installed and latest version
Package redhat-rpm-config-9.1.0-16.fc15.noarch already installed and latest version
Package ca-certificates-2011.78-1.fc15.noarch already installed and latest version
Package python-2.7.1-7.fc15.i686 already installed and latest version
Package python-devel-2.7.1-7.fc15.i686 already installed and latest version
Package python-virtualenv-1.7.1.2-2.fc15.noarch already installed and latest version
Package python-tools-2.7.1-7.fc15.i686 already installed and latest version
Package python-pip-0.8.3-1.fc15.noarch already installed and latest version
Package 1:mod_ssl-2.2.22-1.fc15.i686 already installed and latest version
Nothing to do
Creating virtual environment…
Installing Python packages…
Had a problem while installing Python packages.
pip prints the following errors:
Collecting argparse==1.4.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 11))
/root/.local/share/letsencrypt/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:315: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#snimissingwarning.
  SNIMissingWarning
/root/.local/share/letsencrypt/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
  Downloading argparse-1.4.0-py2.py3-none-any.whl
Collecting pycparser==2.14 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 17))
  Downloading pycparser-2.14.tar.gz (223kB)
Collecting asn1crypto==0.22.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 21))
  Downloading asn1crypto-0.22.0-py2.py3-none-any.whl (97kB)
Collecting cffi==1.10.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 24))
  Downloading cffi-1.10.0.tar.gz (418kB)
Collecting ConfigArgParse==0.10.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 61))
  Downloading ConfigArgParse-0.10.0.tar.gz
Collecting configobj==5.0.6 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 63))
  Downloading configobj-5.0.6.tar.gz
Collecting cryptography==1.9 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 65))
  Downloading cryptography-1.9.tar.gz (409kB)
Collecting enum34==1.1.2 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 84))
  Downloading enum34-1.1.2.tar.gz (46kB)
Collecting funcsigs==1.0.2 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 87))
  Downloading funcsigs-1.0.2-py2.py3-none-any.whl
Collecting idna==2.5 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 90))
  Downloading idna-2.5-py2.py3-none-any.whl (55kB)
Collecting ipaddress==1.0.16 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 93))
  Downloading ipaddress-1.0.16-py27-none-any.whl
Collecting linecache2==1.0.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 96))
  Downloading linecache2-1.0.0-py2.py3-none-any.whl
Collecting ordereddict==1.1 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 99))
  Downloading ordereddict-1.1.tar.gz
Collecting packaging==16.8 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 101))
  Downloading packaging-16.8-py2.py3-none-any.whl
Collecting parsedatetime==2.1 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 104))
  Downloading parsedatetime-2.1-py2-none-any.whl
Collecting pbr==1.8.1 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 107))
  Downloading pbr-1.8.1-py2.py3-none-any.whl (89kB)
Collecting pyOpenSSL==16.2.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 110))
  Downloading pyOpenSSL-16.2.0-py2.py3-none-any.whl (43kB)
Collecting pyparsing==2.1.8 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 113))
  Downloading pyparsing-2.1.8-py2.py3-none-any.whl (54kB)
Collecting pyRFC3339==1.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 122))
  Downloading pyRFC3339-1.0-py2.py3-none-any.whl
Collecting python-augeas==0.5.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 125))
  Downloading python-augeas-0.5.0.tar.gz (90kB)
Collecting pytz==2015.7 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 127))
  Downloading pytz-2015.7-py2.py3-none-any.whl (476kB)
Collecting requests==2.12.1 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 141))
  Downloading requests-2.12.1-py2.py3-none-any.whl (574kB)
Collecting six==1.10.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 144))
  Downloading six-1.10.0-py2.py3-none-any.whl
Collecting traceback2==1.4.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 147))
  Downloading traceback2-1.4.0-py2.py3-none-any.whl
Collecting unittest2==1.1.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 150))
  Downloading unittest2-1.1.0-py2.py3-none-any.whl (96kB)
Collecting zope.component==4.2.2 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 153))
  Downloading zope.component-4.2.2.tar.gz (546kB)
Collecting zope.event==4.1.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 155))
  Downloading zope.event-4.1.0.tar.gz (476kB)
Collecting zope.interface==4.1.3 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 157))
  Downloading zope.interface-4.1.3.tar.gz (141kB)
Collecting mock==2.0.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 175))
  Downloading mock-2.0.0-py2.py3-none-any.whl (56kB)
Collecting letsencrypt==0.7.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 186))
  Downloading letsencrypt-0.7.0-py2-none-any.whl
Collecting certbot==0.16.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 190))
  Downloading certbot-0.16.0-py2.py3-none-any.whl (267kB)
Collecting acme==0.16.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 193))
  Downloading acme-0.16.0-py2.py3-none-any.whl (98kB)
Collecting certbot-apache==0.16.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 196))
  Downloading certbot_apache-0.16.0-py2.py3-none-any.whl (135kB)
Collecting certbot-nginx==0.16.0 (from -r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 199))
  Downloading certbot_nginx-0.16.0-py2.py3-none-any.whl (65kB)
Requirement already satisfied (use --upgrade to upgrade): setuptools in /root/.local/share/letsencrypt/lib/python2.7/site-packages (from zope.component==4.2.2->-r /tmp/tmp.Zl9n8a4w99/letsencrypt-auto-requirements.txt (line 153))
Installing collected packages: argparse, pycparser, asn1crypto, cffi, ConfigArgParse, six, configobj, idna, enum34, ipaddress, cryptography, funcsigs, linecache2, ordereddict, pyparsing, packaging, parsedatetime, pbr, pyOpenSSL, pytz, pyRFC3339, python-augeas, requests, traceback2, unittest2, zope.interface, zope.event, zope.component, mock, acme, certbot, letsencrypt, certbot-apache, certbot-nginx
  Running setup.py install for pycparser: started
    Running setup.py install for pycparser: finished with status 'done'
  Running setup.py install for cffi: started
    Running setup.py install for cffi: finished with status 'done'
  Running setup.py install for ConfigArgParse: started
    Running setup.py install for ConfigArgParse: finished with status 'done'
  Running setup.py install for configobj: started
    Running setup.py install for configobj: finished with status 'done'
  Running setup.py install for enum34: started
    Running setup.py install for enum34: finished with status 'done'
  Running setup.py install for cryptography: started
    Running setup.py install for cryptography: finished with status 'error'
    Complete output from command /root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-B5gte7/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-wOgFK2-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography:
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-i686-2.7
    creating build/lib.linux-i686-2.7/cryptography
    copying src/cryptography/__init__.py -> build/lib.linux-i686-2.7/cryptography
    copying src/cryptography/exceptions.py -> build/lib.linux-i686-2.7/cryptography
    copying src/cryptography/utils.py -> build/lib.linux-i686-2.7/cryptography
    copying src/cryptography/fernet.py -> build/lib.linux-i686-2.7/cryptography
    copying src/cryptography/__about__.py -> build/lib.linux-i686-2.7/cryptography
    creating build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/name.py -> build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/oid.py -> build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/base.py -> build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/__init__.py -> build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/extensions.py -> build/lib.linux-i686-2.7/cryptography/x509
    copying src/cryptography/x509/general_name.py -> build/lib.linux-i686-2.7/cryptography/x509
    creating build/lib.linux-i686-2.7/cryptography/hazmat
    copying src/cryptography/hazmat/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat
    creating build/lib.linux-i686-2.7/cryptography/hazmat/backends
    copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends
    copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends
    creating build/lib.linux-i686-2.7/cryptography/hazmat/bindings
    copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/bindings
    creating build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/mac.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/serialization.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    copying src/cryptography/hazmat/primitives/interfaces.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives
    creating build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-i686-2.7/cryptography/hazmat/backends/openssl
    creating build/lib.linux-i686-2.7/cryptography/hazmat/bindings/openssl
    copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-i686-2.7/cryptography/hazmat/bindings/openssl
    copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/bindings/openssl
    copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-i686-2.7/cryptography/hazmat/bindings/openssl
    creating build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/asymmetric
    creating build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/kdf
    creating build/lib.linux-i686-2.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/ciphers
    copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/ciphers
    creating build/lib.linux-i686-2.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/twofactor
    copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-i686-2.7/cryptography/hazmat/primitives/twofactor
    running egg_info
    writing requirements to src/cryptography.egg-info/requires.txt
    writing src/cryptography.egg-info/PKG-INFO
    writing top-level names to src/cryptography.egg-info/top_level.txt
    writing dependency_links to src/cryptography.egg-info/dependency_links.txt
    writing entry points to src/cryptography.egg-info/entry_points.txt
    warning: manifest_maker: standard file '-c' not found
    reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
    reading manifest template 'MANIFEST.in'
    no previously-included directories found matching 'docs/_build'
    warning: no previously-included files matching '*' found under directory 'vectors'
    writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
    running build_ext
    generating cffi module 'build/temp.linux-i686-2.7/_padding.c'
    creating build/temp.linux-i686-2.7
    generating cffi module 'build/temp.linux-i686-2.7/_constant_time.c'
    generating cffi module 'build/temp.linux-i686-2.7/_openssl.c'
    building '_openssl' extension
    creating build/temp.linux-i686-2.7/build
    creating build/temp.linux-i686-2.7/build/temp.linux-i686-2.7
    gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables -D_GNU_SOURCE -fPIC -fwrapv -fPIC -I/usr/include/python2.7 -c build/temp.linux-i686-2.7/_openssl.c -o build/temp.linux-i686-2.7/build/temp.linux-i686-2.7/_openssl.o
    build/temp.linux-i686-2.7/_openssl.c:481:26: fatal error: openssl/cmac.h: No such file or directory
    compilation terminated.
    error: command 'gcc' failed with exit status 1
Command "/root/.local/share/letsencrypt/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-B5gte7/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-wOgFK2-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/pip-build-B5gte7/cryptography
You are using pip version 8.0.3, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/ .
My web server is (include version): Apache (httpd-2.2.22-1)
The operating system my web server runs on is (include version): Fedora Core 15
https://certbot.eff.org/docs/using.html
--no-self-upgrade (certbot-auto only) prevent the certbot-auto script
from upgrading itself to newer released versions
(default: Upgrade automatically)
You can check if certbot-auto is still working but I am thinking because you did not stop it from upgrading the upgrade has broken your certbot-auto install
Andrei
