Can you please post the exact output from your terminal? You can wrap the output inbetween the following symbols to format it nicely. Example:
$ user@host: ./certbot-auto renew
hi @Phil
[root@localhost letsencrypt]# ./certbot-auto renew
Bootstrapping dependencies for RedHat-based OSes… (you can skip this with --no-bootstrap)
yum is /usr/bin/yum
yum is hashed (/usr/bin/yum)
Loaded plugins: fastestmirror, refresh-packagekit
Setting up Install Process
Loading mirror speeds from cached hostfile
updates: mirror.kakao.com
Package augeas-libs-1.0.0-10.el6.x86_64 already installed and latest version
Package openssl-1.0.1e-58.el6_10.x86_64 already installed and latest version
Package openssl-devel-1.0.1e-58.el6_10.x86_64 already installed and latest version
Package libffi-devel-3.0.5-3.2.el6.x86_64 already installed and latest version
Package redhat-rpm-config-9.0.3-51.el6.centos.noarch already installed and latest version
Package ca-certificates-2018.2.22-65.1.el6.noarch already installed and latest version
Package python-devel-2.6.6-68.el6_10.x86_64 already installed and latest version
Package python-virtualenv-12.0.7-1.el6.noarch already installed and latest version
Package python-tools-2.6.6-68.el6_10.x86_64 already installed and latest version
Package python-pip-7.1.0-2.el6.noarch already installed and latest version
Package 1:mod_ssl-2.2.15-69.el6.centos.x86_64 already installed and latest version
Resolving Dependencies
–> Running transaction check
—> Package gcc.x86_64 0:4.4.7-18.el6_9.2 will be updated
–> Processing Dependency: gcc = 4.4.7-18.el6_9.2 for package: gcc-c+±4.4.7-18.el6_9.2.x86_64
—> Package gcc.x86_64 0:4.4.7-23.el6 will be an update
—> Package gcc-c++.x86_64 0:4.4.7-18.el6_9.2 will be updated
—> Package gcc-c++.x86_64 0:4.4.7-23.el6 will be an update
–> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Updating:
gcc x86_64 4.4.7-23.el6 base 10 M
Updating for dependencies:
gcc-c++ x86_64 4.4.7-23.el6 base 4.7 M
Transaction Summary
Upgrade 2 Package(s)
Total download size: 15 M
Downloading Packages:
^C/2): gcc-4.4.7-23.el6.x86_64.rpm (19%) 27% [============== ] 0.0 B/s | 2.8 MB --:-- ETA
Current download cancelled, interrupt (ctrl-c) again within two seconds
to exit.
I’m sorry about your authority.
I solved the question of authority.
chattr -i /usr/bin/gcc /usr/bin/g++
chmod 700 /usr/bin/gcc /usr/bin/g++;
