You only issued the certificate for stjornuljos.is. You need to issue it for both stjornuljos.isandwww.stjornuljos.is if you want the certificate to be valid for both names.
Since you didn't fill out any of the other questions, I can't provide any information on how to go about doing that for your system.
However, after that, you probably want to remove the original certificate. You can do this with certbot certificates to show you a list of the certificates on your server (probably just this one), and then use certbot delete to remove the “bad” one by name. Note that you will still receive a renewal reminder for this one, but you can safely ignore it as you won’t be using this certificate anymore.
EDIT: Do the delete after you get a new certificate. I think there may still be a bug where deleting first can cause issues with re-issuing a subsequent certificate.
sudo certbot --apache -d stjornuljos.is -d www.stjornuljos.is
Error while running apache2ctl configtest.
Action ‘configtest’ failed.
AH00526: Syntax error on line 16 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file ‘/etc/letsencrypt/live/stjornuljos.is/fullchain.pem’ does not exist or is empty
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError(“Error while running apache2ctl configtest.\nAction ‘configtest’ failed.\nThe Apache error log may have more information.\n\nAH00526: Syntax error on line 16 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:\nSSLCertificateFile: file ‘/etc/letsencrypt/live/stjornuljos.is/fullchain.pem’ does not exist or is empty\n”,)
Ah, darn, I made my edit after you already read my post. I had overlooked the fact that deleting the certificate before creating the new one causes issues and changed my post to say to change the order of operations on this, but not in time it would seem.
I think the “best” way to fix this would be to remove the le-ssl config files and try again. Sorry about that!
