[SOLVED] DNSSEC problem not sure what to do
My domain is: cataclysm games
I ran this command: sudo certbot renew --dry-run
It produced this output: dns problem: servfail looking for A for cataclysm.games
My web server is (include version): Ngnix
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: namecheap.com
It looks like a problem with DNSSEC however I am unsure how to fix it.
My registrar does not support DNSSEC: ‘Sorry, DNSSEC is not available on this domain because this particular TLD (domain extension) does not support DNSSEC at the registry level.’
https://letsdebug.net/cataclysm.games/7634
https://unboundtest.com/m/CAA/cataclysm.games/KQQIODRI
It's not actually a DNSSEC problem.
The domain's set to use two of Namecheap's nameservers:
cataclysm.games.        86400   IN      NS      dns1.registrar-servers.com.
cataclysm.games.        86400   IN      NS      dns2.registrar-servers.com.
DNSSEC is off.
The nameservers are actually returning a SERVFAIL -- short for "server failure" -- error code:
$ dig +norecurse cataclysm.games @dns1.registrar-servers.com
; <<>> DiG 9.13.3-3+ubuntu16.04.1+deb.sury.org+1-Ubuntu <<>> +norecurse cataclysm.games @dns1.registrar-servers.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 4352
;; flags: qr; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;cataclysm.games.               IN      A
;; Query time: 15 msec
;; SERVER: 2620:74:19::33#53(2620:74:19::33)
;; WHEN: Tue Nov 06 05:40:55 UTC 2018
;; MSG SIZE  rcvd: 44
Something's broken or misconfigured at Namecheap. You have to contact them to fix it.
That error message is false, by the way. The TLD supports DNSSEC. Namecheap just doesn't support it well.
Source: http://stats.research.icann.org/dns/tld_report/
Thank you so much!
I contacted Namecheap and the problem was a CNAME record for my bare domain.
I removed the CNAME record and the response from dig was 'NOERROR'.
The only record I have at the DNS register now with Namecheap is an A record.
Running the auto renew command now passes.
Thanks Again!
Solved.
