I wonder if it is possible, we are not able to update to Leap 15
please can anyone help with a link or something?
thanks in advance
thanks in advance
Hi @annlee
do you want to install certbot? If you can't use the Leap 15 - version, try the generic certbot-auto - version.
If you select
your webserver, then "Other unix", you see the generic solution.
wget https://dl.eff.org/certbot-auto
chmod a+x certbot-auto
Certbot-auto accepts the same commands like certbot.
sounds good, I will be trying the generic solution and get you informed,
thanks a lot
