My certificate was created successfully. However, my website will not load using https://mds-enterprises.com or https://www.mds-enterprises.com.
mds-enterprises.com
certbot certonly --apache
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel): [redacted]
https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf. You must
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/(C)ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let's Encrypt project and the non-profit
organization that develops Certbot? We'd like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
1: mds-enterprises.com
2: www.mds-enterprises.com
blank to select all options shown (Enter 'c' to cancel): 1 2
http-01 challenge for mds-enterprises.com
http-01 challenge for www.mds-enterprises.com
Enabled Apache rewrite module
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/mds-enterprises.com/fullchain.pem
/etc/letsencrypt/live/mds-enterprises.com/privkey.pem
Your cert will expire on 2023-02-10. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
"certbot renew" -
Your account credentials have been saved in your Certbot
making regular backups of this folder is ideal. -
Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation -
We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
root@mds-enterprises:~# systemctl status certbot.timer
● certbot.timer - Run certbot twice daily
Loaded: loaded (/lib/systemd/system/certbot.timer; enabled; vendor preset:>
Active: active (waiting) since Sat 2022-11-12 14:44:59 UTC; 2min 46s ago
Trigger: Sun 2022-11-13 06:08:13 UTC; 15h left
Triggers: ● certbot.service
Nov 12 14:44:59 mds-enterprises.com systemd[1]: Started Run certbot twice daily.
Apache/2.4.41 (Ubuntu)
Ubuntu 20.04.5 LTS (GNU/Linux 5.4.0-131-generic x86_64)
OVHCloud
Yes
No
certbot 0.40.0
