fmwebs
June 4, 2019, 12:46pm
1
My domain is: https://www.ohioemsnews.com
My hosting provider, if applicable, is: JustHost
When I go to my website it says my site is not fully secure. When I log into the admin area is says it is secure. What am I doing wrong?
It will only let me add 1 screenshot for help sorry
Hi @fmwebs
there are some errors ( https://check-your-website.server-daten.de/?q=ohioemsnews.com ):
Your standard urls:
http + www isn't redirected to https, so that version isn't secure. https + non-www is redirected to http + www, that's bad - never redirect https to http.
And you have some content errors. Sample:
And a lot of scripts (check the complete list), which are http links (not https). So your site doesn't work as expected. And the browser shows warnings.
fmwebs
June 4, 2019, 11:51pm
3
thank you for your help. I found a WordPress plugin that fixed everything. you guys are great! keep up the great work and Let’s Encrypt the world!
you still have some serios issues.
look at the report from @JuergenAuer and make sure to fix the issues.
Ah, thanks - there is a new check of your domain, perhaps @Nexo1960 has checked your domain.
The http script links are fixed, that's good.
One script is missing, that's the last Grade I:
script
src
https://www.ohioemsnews.com/wp-content/themes/news-mix-light/js/jquery.caroufredsel-6.0.4-packed.js
404
Not Found
1
missing file
Result should be a H, the http + www version doesn't redirect to https. So if a user selects that version, the user isn't secure.
fmwebs:
WordPress
No, I don't use Wordpress (20 characters )
fmwebs
June 20, 2019, 4:00pm
10
Download the plugin “Really simple ssl” and activate it. Then at the top is will ask to start it and that is it. The plugin has a yellow lock as icon.
I did , but the padlock appears then "not secure " appears a few minutes later, this only started after importing a demo for a theme
fmwebs
June 20, 2019, 4:03pm
12
Just checking the basics…Did you change the URL to https:// in the WordPress settings?
I assumed it did that automatically since that’s how it appears in the url bar, but let me try editing that
It is indeed https:// , is the problem the theme demo?
fmwebs
June 20, 2019, 4:17pm
15
try changing themes and see if it corrects itself
