Site not trusted on some devices
Hello,
I’m getting reports from users, that my site is not accessble. iOS devices rightout say “not trusted” and refuse to load it and one user has the same problem with firefox Focus on android saying it’s because the certificate is self-signed.
Is there a way to rectify this? Or do I need a non-selfsigned certificate?
My domain is: fictionalmaps.com
Apache2 v2.4.25
Debian 9
strato
no
0.28.0
Hi @DM_Resources
you have created the wrong certificate - see https://check-your-website.server-daten.de/?q=fictionalmaps.com
CN=fictionalmaps.com
	21.05.2020
	19.08.2020
expires in 51 days	fictionalmaps.com - 1 entry
So your www version isn't included.
Result:
http://fictionalmaps.com/ 85.214.239.14 301 https://fictionalmaps.com/ Html is minified: 100,00 % 0.010 A
http://www.fictionalmaps.com/ 85.214.239.14 301 https://fictionalmaps.com/ 0.187 E
https://www.fictionalmaps.com/ 85.214.239.14 301 https://fictionalmaps.com/ 3.220 N
Certificate error: RemoteCertificateNameMismatch
https://fictionalmaps.com/ 85.214.239.14 GZip used - 20361 / 66075 - 69,19 % Inline-JavaScript (∑/total): 24/36688 Inline-CSS (∑/total): 2/4720 200 Html is minified: 313,79 % 4.110 B
If a user adds www, it's insecure.
Create one certificate with both domain names and use that.
Ah, thank you! That makes sense!
Excuse if I ask ignorantly: how do I create a certificate for both?
I’m a complete beginner when it comes to SSL, so I used these instructions: https://certbot.eff.org/lets-encrypt/debianstretch-apache
It seemed to work, but nowhere in there do I specify the domain name.
Read
https://certbot.eff.org/docs/using.html
Thank you, I will read it thoroughly.
