I ran this command: sudo /path/certbot-auto --apache
It produced this output: everything went ok, selected the nameserver from the list (there was only 1) and I got the congratuilions output that said everything went ok. I choosed not to have the redirect (luckyly, because the https doesn’t work)
My web server is (include version): Apache 2.2.15
The operating system my web server runs on is (include version): CentOS Linux 6.9
My hosting provider, if applicable, is: Aruba
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Webmin 1.881
The problem: https://incipio.it is not reachable, while http is. What can I do?
I also noticed a problem with apache regarding this stuff:
“httpd: Syntax error on line 1022 of /etc/httpd/conf/httpd.conf: Syntax error on line 9 of /etc/httpd/conf/httpd-le-ssl.conf: Could not open configuration file /etc/letsencrypt/options-ssl-apache.conf: No such file or directory”
Line 1022 is: Include /etc/httpd/conf/httpd-le-ssl.conf
Line 9 of other file is: Include /etc/letsencrypt/options-ssl-apache.conf
maybe I have to change something here?
You can create it,
This is what mines looks like - but I may have modified it a bit more options-ssl-nginx.conf
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
