I can also edit through webmin if you say me what I should write and where
Add
ServerAlias incipio.it
right after
ServerName www.incipio.it
in both files:
/etc/httpd/conf/httpd-le-ssl.conf
/etc/httpd/conf/httpd.conf
restart web server
Done.
Https still not reachable
wget https://www.incipio.it/
–2018-05-08 09:20:31-- https://www.incipio.it/
Resolving www.incipio.it (www.incipio.it)… 80.211.142.114
Connecting to www.incipio.it (www.incipio.it)|80.211.142.114|:443… failed: No route to host.
wget https://incipio.it/
–2018-05-08 09:20:36-- https://incipio.it/
Resolving incipio.it (incipio.it)… 80.211.142.114
Connecting to incipio.it (incipio.it)|80.211.142.114|:443… failed: No route to host.
Is port 443 allowed or blocked?
Does it reach your web server?
Can you check the web server logs?
I have created a firewall rule: If protocol is TCP and destination port is 443 and state of connection is NEW = Accept
error_log of apache:
[notice] Apache/2.2.15 (Unix) DAV/2 mod_fcgid/2.3.9 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips mod_wsgi/3.2 Python/2.6.6 configured – resuming normal operations
[Tue May 08 14:54:33 2018] [error] [client .*.***.***] script ‘/home/incipio.it/www/ip_js.php’ not found or unable to stat
[Tue May 08 15:05:37 2018] [error] [client .*.***.***] script ‘/home/incipio.it/www/ip_js.php’ not found or unable to stat
[Tue May 08 15:07:06 2018] [notice] caught SIGTERM, shutting down
[Tue May 08 15:07:11 2018] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue May 08 15:07:11 2018] [notice] Digest: generating secret for digest authentication …
[Tue May 08 15:07:11 2018] [notice] Digest: done
[Tue May 08 15:07:11 2018] [notice] Apache/2.2.15 (Unix) DAV/2 mod_fcgid/2.3.9 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips mod_wsgi/3.2 Python/2.6.6 configured – resuming normal operations
[Tue May 08 15:17:01 2018] [error] [client .*.***.***] script ‘/home/incipio.it/www/ip_js.php’ not found or unable to stat
[Tue May 08 15:28:29 2018] [error] [client .*.***.***] script ‘/home/incipio.it/www/ip_js.php’ not found or unable to stat
still fails for me:
–2018-05-08 09:48:27-- https://www.incipio.it/
What can be? Should I do something with firewall or is it something more?
I think the firewall is not playing nice.
But I don’t know which firewall you have nor how to correct it.
And this is really not a firewall related forum - although I am a firewall guy.
I would suggest you seek help from your firewall forum.
Can you help me understand what kind of Firewall I have? I read Linux Firewall and I have for ipv4 and ipv6. Is it the basic firewall of centOS?
Then it is CentOS firewall.
Look for help using “CentOS firewall https failed no route to host”
I tried deactivating the firewall temporarily and the browser result was: ERR_SSL_PROTOCOL_ERROR
So the firewall was blocking, but without firewall it still doesn’t work.
Show that file again.
You said you replaced it.
Here it is:
# this file.
SSLEngine on
# Intermediate configuration, tweak to your needs
SSLProtocol +TLSv1 +TLSv1.1 +TLSv1.2
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder on
SSLOptions +StrictRequire
# Add vhost name to log entries:
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\"" vhost_combined
LogFormat "%v %h %l %u %t \"%r\" %>s %b" vhost_common
#CustomLog /var/log/apache2/access.log vhost_combined
#LogLevel warn
#ErrorLog /var/log/apache2/error.log
# Always ensure Cookies have "Secure" set (JAH 2012/1)
#Header edit Set-Cookie (?i)^(.*)(;\s*secure)??((\s*;)?(.*)) "$1; Secure$3$4"
nothing strange there.
Start with the httpd.conf file and review each line and then each line in each included file.
The problem is in there somewhere…
the problem is I will probably read 10 lines of errors and noticing nothing wrong
Is there something wrong here?
<VirtualHost *>
DocumentRoot “/home/incipio.it/www”
<Directory “/home/incipio.it/www”>
allow from all
Options None
NameVirtualHost *:443
Include /etc/httpd/conf/httpd-le-ssl.conf
post them here
then maybe someone can help you review them
<VirtualHost *>
allow from all
Options None
the very first line is wrong - no port would bind it to all ports
Use a specific IP:port:
<VirtualHost 1.2.3.4:443>;
( replace 1.2.3.4 with your actual internal IP )
Use any IP:port:
<VirtualHost *:443>;
Guys now it connects to site but gives this message:
NET::ERR_CERT_COMMON_NAME_INVALID
like if the certificate is not valid…why?
