Site is not safe
My domain is: https://www.povej.net/
I still have this error site not safe
Certificate is one month old
The operating system my web server runs on is (include version): centos 7.6
certbot 0.36.0
Hi @Blisk
if you use the ip address, your site is always not safe.
Use your domain name. Letsencrypt certificates have only domain names, so that can't work with an ip address.
Checking your domain there are other errors - https://check-your-website.server-daten.de/?q=povej.net
There are some certificates
Let's Encrypt Authority X3 2019-09-16 2019-12-15 www.povej.net - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-09-14 2019-12-13 snorby.povej.net - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-09-11 2019-12-10 povej.net - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-09-10 2019-12-09 muzika.povej.net - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-09-10 2019-12-09 files.povej.net - 1 entries duplicate nr. 1
but you use the wrong certificate:
CN=muzika.povej.net
	10.09.2019
	09.12.2019
expires in 84 days	muzika.povej.net - 1 entry
So first step: Create one certificate with both domain names (non-www and www) and use that.
thank you for detail answer.
ecerything works except www.povej.net
don’t know where is a problem I already renewed certificate but get the same error.
Hi @Blisk,
Checking the certificate for povej.net shows that it only has a SAN for povej.net when in reality you want the SANs to be www.povej.net and povej.net
$ echo | openssl s_client -connect povej.net:443 -servername povej.net -verify_hostname povej.net 2>/dev/null | openssl x509 -noout -text | grep -oP '(?<=DNS:)[^,]+'
povej.net
Here’s the same test checking for www.povej.net
$  echo | openssl s_client -connect www.povej.net:443 -servername www.povej.net -verify_hostname www.povej.net | grep -i Verification
Verification error: Hostname mismatch
$ echo | openssl s_client -connect www.povej.net:443 -servername www.povej.net -verify_hostname www.povej.net 2>/dev/null | openssl x509 -noout -text | grep -oP '(?<=DNS:)[^,]+'
povej.net
If you used certbot, you could use this example to try issuing for multiple domains.
Thank you for your help.
I did some more research and found out I have wrong settings in apache, now it works.
