Single Certificate for sub domains pointing to different IP addresses
I am having 5 IP addresses pointing to multiple sub domains and are being hosted on different servers.
I was able to create certificates for sub domains pointing to single IP address but not for different IP addresses. I have tried using webroot path and manual authentication but no luck since other sub domains are being hosted on different servers LE is not able to validate I guess.
Since I am using failover for those domains SSL Verification is failing by saying mismatch occurred. When it is pointing to the Correct CNAME record no issues, if the server is down and if we change the CNAME record to other sub domain mismatch occurs. All I need a single Certificate for all sub domains pointing to different IP. Is there a solution for that?
Ex: example.com CNAME www.example.com (Works Fine)
example.com CNAME test.example.com (Mismatch Occurs)
It’s perfectly possible, yes.
Using the official certbot client, then using the DNS challenge is the easiest way of doing this.
If you don’t have access to your DNS via an API (without which it’s more difficult to automate the process), then try the GetSSL alternative client, which was written specifically for working with domains on remote servers. Note: I wrote the GetSSL script, so am not totally unbiased in my answer here :wink:
Can’t we use http challenge instead of DNS challenge
You can, yes - the certbot client doesn’t currently allow you to do that over different servers - GetSSL does though, so you can use that for the http challenge with domains on different remote servers.
It is saying can’t reach "http:///.well-known/acme-challenge/Ql4K2s78dVS220eu14EBD6WsiRLfxlcoZZlJAuYElRg
I need a little more information that that. It sounds as if you haven’t included the domain name correctly into the config.
If you like, email me the complete getssl.cfg file for the domain(s) you want to obtain to getssl at serverco.com. Alternatively you can paste it here or, ideally, on the getssl issues pages on github.
You can do this with certbot and http challenge, assuming all servers run http servers.
You write a script that first mounts the webroots of the servers locally. In my case I uses sshfs
sshfs root@host1:/var/www/html/ /mnt/host1 -o sshfs_sync,IdentityFile=id_ed25519
sshfs root@host2:/var/www/html/ /mnt/host2 -o sshfs_sync,IdentityFile=id_ed25519
Now we can run certbot and have it do the http challenge, since it has write access to all webroots.
certbot --text --webroot --webroot-path /mnt/host1 -d host1.com --webroot-path /mnt/host2 -d host2.com
In this command there are multiple --webroot-paths, one before each hostname. certbot will write one token-file to each location.
and finally unmount, in my case
fusermount -u /mnt/host1
fusermount -u /mnt/host2
Now just distribute the certificate to the servers using scp or mounts, and restart the daemons.
@kkp, that’s a nice technique! Thanks for sharing it.
@serverco My bad I have given wrong web root path so that’s why it is throwing error. It’s working now
@kkp Do I have to again mount the web root path locally again for running the cerbot renew
Yes, it will normally have to perform the same validation process over again and would need the same resources available to do the renewal validation that you used to do the original validation.
@schoen Thank you.
I have mounted the root path locally when I run the ./letsencrypt certonly --webroot --webroot-path /mnt/host/ --renew-by-default --text --agree-tos -d <domain name>. It is saying /mnt/host/ does not exist or is not a directory . It`s permissions issue I guess.
@Muneer, can you confirm that you can use /mnt/host as a directory, like ls /mnt/host and touch /mnt/host/sample-file?
I can read files but I can’t write it in the directory
Are you running the client with sudo?
I have added allow_other option to the sshfs command now I was able to write into that mount point.
Now I was able to generate certificate for that web root path that I have mounted locally.
sshfs mounts are nice.
You could also use something like rclone to sync your ssl certs to multiple cloud storage providers and configure each server’s vhost to look for them at the sync’d paths. for my Centmin Mod LEMP stack working on addons/rclone.sh https://community.centminmod.com/posts/39190/ which will be able to sync my letsencrypt ssl certs to say Dropbox, Google Drive or OneDrive or Amazon S3 and have my nginx servers look to the local sync directory for ssl certs instead.
I have mounted all the web root directories locally using sshfs when I used staging server it has given response as The dry run was successful.
But when I tried to run it on the production server it was saying Internal Server Error.
The command I have used is
./certbot-auto certonly --text --agree-tos --webroot --webroot-path /mnt/host1/ -d <Domain Name> --webroot-path /mnt/host2/ -d <Domain Name1> -d <Domain Name2> --webroot-path /mnt/host3/ -d <Domain Name> --webroot-path /mnt/host4/ -d <Domain Name> --webroot-path /mnt/host5 -d <Domain Name>.
see the letsencrypt status page - https://letsencrypt.status.io/
Incident Status Partial Service Disruption : acme-v01.api.letsencrypt.org (Production)
October 31, 2016 5:44AM UTC[Investigating] We are looking into a problem causing some users to experience errors when attempting to issue a certificate.
Technique I am using might be helpful. I have multiple domains and subdomains providing by same server and multiple servers providing for same domain for load balancing. What I did was I proxied all /.well-known/ requests to any of my webservers to another server used specifically for renewing certificates. Let’s call this server crt-srvr.
I create or renew all certificates on this server only and I can do it for any domain I own, because all http/s requests to .well-known directory are going to this server. After certificates are renewed, I just distribute them to servers that needs them. For that purpose I have directories with certs mounted as shared NFS on said servers. It’s easier than physically copy them on dozens of machines. On said machines I have a cron job that just reload webserver every night, but I’m thinking about creating a script. Little dirty solution but I’m too lazy to make better one.
Freaking brilliant.
One of my companies provides multi-instance, high traffic, WordPress hosting + I’ve been wracking my brain about how to handle multi-instance SSL cert generation + renewals.
sshfs completely slipped my mind.
Thanks for providing this info.
