Setting up certificate with ISP port 80 block?
My domain is: setzco.dyndns.org
certbot --apache -d setzco.dyndns.org
Requesting a certificate for setzco.dyndns.org
http-01 challenge for setzco.dyndns.org
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
apache (Fedora 33)
Fedora 33
dyndns.org
yes??
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.14.0
Have apache running on port 8081 since ISP blocks port 80. This works fine, but have seen browsers that are not liking unencrypted connections, so have just started looking at ways to set it up? But since port 80 is blocked, is this a dead end for this process?? Is there a way to get it to work with port 8081 instead of port 80? Thanks
If your ISP doesn't block port 443 (HTTPS), you could try use the the "TLS-ALPN" challenge type. You will need to port forward port 443 first.
Certbot doesn't support it, but other clients like acme.sh do.
acme.sh --issue --alpn --pre-hook "service apache2 stop" --post-hook "service apache2 start" -d setzco.dyndns.org
The DNS challenge might be an option as well, but I have a hard time remembering whether dyndns/Oracle Dyn is supported by clients, and on what free/paid plans it is supported.
