Selecting a LetsEncrypt Client for OpenBSD 6.0
So far none of the guides have worked at all. The typical LE source from github where you use ‘letsencrypt-auto certonly’ is incapable of recognizing that OS. Although, I did initially run that on 5.8 and was able to get a cert on OpenBSD during testing over 6 months ago.
Instead, it is now recommended to use the -current branch of 6.0 (which I am not), or use acme-client. acme-client is incapable of working as well:
acme-client: /etc/acme/privkey.pem: account key exists (not creating)
acme-client: /etc/ssl/acme/private/privkey.pem: domain key exists (not creating)
acme-client: /etc/ssl/acme/private/privkey.pem: PEM_read_PrivateKey
2256225808:error:0906D06C:PEM routines:PEM_read_bio:no start line:/usr/src/lib/libcrypto/crypto/../../libssl/src/crypto/pem/pem_lib.c:704:Expecting: ANY PRIVATE KEY
acme-client: bad exit: keyproc(33902): 1
I have used this guide and followed it the letter, but it does not work whatsoever.
Also have tried this one too.
Has anybody installed a cert on OpenBSD 6.0?
try https://github.com/Neilpang/acme.sh , it supports openbsd.
@n1n2
can you do me a favour and run the following commands
python --version
pip freeze
this will tell me if your OpenBSD install can obtain Cerbtot via the Python PIP Package Manager
Andrei
