SAN certificate for OCP/MAS8
My domain is: acnixiam.com
I ran this command: NA
It produced this output: NA
My web server is (include version): NA
The operating system my web server runs on is (include version): NA
My hosting provider, if applicable, is: AWS
I can login to a root shell on my machine (yes or no, or I don't know): NA
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NA
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): NA
In our environment there are several subdomain and we want SAN certificate to meet our requirement. We are looking for solution to mitigate our issue, price is also important factor as it's a non-prod environment.
Is that system accessible to the public internet? Because I don't see any A or AAAA records in the DNS so I am thinking it may be on a private network. An HTTP Challenge will require that name to reply to HTTP queries from the public internet.
Do you have update authority to the Route53 DNS? Because you can get a cert using a DNS Challenge but you need to be able to update the DNS records.
The Getting Started section is helpful if you have not yet reviewed it: Documentation - Let's Encrypt
Lastly, your Route53 DNS name servers have a likely problem. This should be fixed regardless of whether you continue with Let's Encrypt. I mention this only as I saw it while researching your question.
You need to make sure that the 4 nameservers listed under "Hosted zone details" in the Route 53 console are the same ones listed at both your registrar, and in the NS record for your zone. See "Step 4" of the AWS Docs here: Making Route 53 the DNS service for an inactive domain - Amazon Route 53
See this DNSviz report for the error
https://dnsviz.net/d/acnixiam.com/dnssec/
Hi Mike,
First of all thanks a lot for replying. Below are the answers to your questions.
MAS8 installation has created several sub domain levels during installation that’s the reason we need SAN certificate.
Hope this answers your question. Please let me know if you need more information.
Regards,
Brish
It's very unclear what you're asking. All public CAs use the Subject Alternate Name (SAN) field to list the names in their certificates. Let's Encrypt allows up to 100 names, though the process of it checking all of them can take a while so generally fewer than that works better.
Regardless, as @MikeMcQ said, the domain names you use need to be working names in the global public DNS. (The actual host names don't need to resolve if you use the DNS-01 challenge and can have your certificate process update the TXT records in your DNS, but it needs to be a public working DNS server for a real name.)
Hopefully that helps point you in the right direction. I also recommend looking through Let's Encrypt's documentation; there's a lot there on how it works.
