Same certificate on 2 servers
Hello,
I would like to know if it is a problem to have the same certificate on two servers at the same time.
I will be doing a website migration from a server to another soon and would like to test if the new server along with the https are working properly. So i’m planning to copy the certificates from the current server to the new one.
I will be updating my /etc/hosts locally to test that everything works properly. Is it OK to have the same certificates on two servers in parallel ?
My domain is homunity.com, and has been renewed yesterday for 23 of may. Is it ok to do the migration now ?
Thank you very much !
Hi @Choppy
that's not a problem, that's good. You can use the same certificate with multiple servers.
Ok thanks a lot for the quick answer ! You are great !
