Running certbot behind proxy
I'm running certbot on a server (RHEL 8) behind a company proxy. It works well if I set the proxy via environment variable (export https_proxy=...). After I set https_proxy, the auto-renewal worked for quite a while.
However, during the last maintenance window, probably some RHEL update was installed, or whatever it was, but https_proxy wasn't set anymore. I didn't notice, and some certs expired. I need a more permanent way to set the proxy. I know how to do it when it's triggered by a cron job, but since I installed the certbot as a snap, I don't have a clue anymore what exactly triggers the certbot or where to set the proxy. Please advice.
Regards,
Mario
Since it is a systemd unit, something like this might work:
$ cat /etc/systemd/system/snap.certbot.renew.service.d/override.conf
[Service]
Environment=HTTPS_PROXY=https://192.168.0.1
(can also create the file by using systemctl edit snap.certbot.renew.service and pasting the two lines in).
Also don't forget to systemctl daemon-reload afterwards for it to take effect!
