Certbot cron renewal not working with proxy
I’ve recently had to install a forward proxy on the machine that certbot is running on, but I can’t seem to get certbot to use it.
There are some posts here which imply my approach should work. But the posts are a bit old so I don’t know if certbot has changed in that time.
I don’t know whether the envars are case-sensitive so I’ve tried both, and also put them into /etc/environment.
My domain is: www.hatters.org.uk
I ran this command (in /etc/cron.d/certbot):
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
http_proxy=http://localhost:8888/
https_proxy=http://localhost:8888/
HTTP_PROXY=http://localhost:8888/
HTTPS_PROXY=http://localhost:8888/
0 */12 * * * root test -x /usr/bin/certbot -a \! -d /run/systemd/system && perl -e 'sleep int(rand(43200))' && certbot -q renew -i apache -a apache/etc/cron.d/certbot
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 852, in _validate_conn
    conn.connect()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f886d61f978>: Failed to establish a new connection: [Errno 111] Connection refused
Apache 2.4.29
Ubuntu 18.04.3
Jump Networks Ltd
Yes
I’m not using a control panel
The version of my client:
0.31.0
You’re using systemd, so the cron job is ignored.
See if you can set the environment variables with the systemd service.
Ah, yes! The cron command is the default that comes with cerbot on Ubuntu so I hadn’t thought about that.
Now I need to work out how to give envars to systemd… :frowning:
Hi @gilgongo,
This doc should show you how to use env vars in systemd. I use something similar on one of my boxes. https://coreos.com/os/docs/latest/using-environment-variables-in-systemd-units.html
Hm. I’ve tried giving systemd the proxy env but it still not working. Perhaps I’ve got another problem. I’ll create a separate ticket.
Try this. I had similar issue with proxy server and firewall.
This is how I got it working. I added export line in front of the certbot renew command. My system is CentOS 7. Following is the line in my cron job.
0 0 * * 0 export HTTPS_PROXY=http://yourproxy:port && /usr/bin/certbot renew
You can add > /tmp/somelogfile at the end of the line to get the screen output saved.
Hope this works for you.
Thanks - I tried something similar but it turns out the certbot package for Ubuntu uses a systemd timer and not cron. The crontab that ships with the package doesn’t do anything, and activating it may in fact cause problems. Why that is, I don’t know. But in the end I solved the proxy issue by setting the envvar in the certbot systemd unit file.
