Running certbot as root
usmcmta.org
letsencrypt-auto
su or sudo not found (don’t remember exact verbiage)
Apache
Linux
No
Yes.
I am in a shared hosting environment on Godaddy. I attempted to install certbot from the command line, only to discover that it requires root privileges. I initially called Godday to see if I could get sudo privileges to complete the install, but then after reading over the installation script, I see that it actually requires to be run as root. Why?
Why does certbot run as root and not as a user? In a shared hosting environment, I can’t use Let’s Encrypt. I love the idea of using open source technology, but I can’t in my enviromnet. Certbot should run as either the user installing it, or a service account, but its not a good practice to run it as root.
Thank you.
Daryl
certbot-auto needs root access to install some dependencies from your server’s Linux distribution. It does not necessarily need root to function once installed, but certbot usually is used to install the certificates for you too and that does require root access.
For shared hosting, lightweight clients like acme.sh are usually preferred. These have lighter dependencies than full-featured clients, so you can usually get away with not installing anything as long as you have the basic necessities like openssl installed.
In fact, if you use GoDaddy’s CPanel-based hosting, you can actually automate the entire issuance process with it, including installing the certificate with the CPanel API:
Thank you patches. I’ll look into using acme.sh.
Daryl
