My domain is: gaming-evolution.net
Processing /etc/letsencrypt/renewal/ranksystem.gaming-evolution.net.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/teamspeak.gaming-evolution.net.conf
Processing /etc/letsencrypt/renewal/gaming-evolution.net.conf
http-01 challenge for gaming-evolution.net
Waiting for verification…
Attempting to renew cert (gaming-evolution.net) from /etc/letsencrypt/renewal/gaming-evolution.net.conf produced an unexpected error: Failed authorization procedure. gaming-evolution.net (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://gaming-evolution.net/.well-known/acme-challenge/JQbg6wkXjwNMQYRhc--tlfAOci-QHlTNtZjEkpdvfG8 [176.9.22.165]: "\n\n \n <meta charset=“utf-8”>\n <meta http-equiv=“X-UA-Compatible” content=“IE=edge”>\n ". Skipping.
Processing /etc/letsencrypt/renewal/tswi.gaming-evolution.net.conf
http-01 challenge for tswi.gaming-evolution.net
Encountered exception during recovery:
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 75, in handle_authorizations
resp = self._solve_challenges(aauthzrs)
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 132, in _solve_challenges
resp = self.auth.perform(all_achalls)
File “/usr/lib/python3/dist-packages/certbot/plugins/webroot.py”, line 83, in perform
self._create_challenge_dirs()
File “/usr/lib/python3/dist-packages/certbot/plugins/webroot.py”, line 172, in _create_challenge_dirs
stat_path = os.stat(path)
FileNotFoundError: [Errno 2] No such file or directory: ‘/var/www/tswi.gaming-evolution.net’
File “/usr/lib/python3/dist-packages/certbot/error_handler.py”, line 108, in _call_registered
self.funcs-1
File “/usr/lib/python3/dist-packages/certbot/auth_handler.py”, line 316, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/usr/lib/python3/dist-packages/certbot/plugins/webroot.py”, line 224, in cleanup
os.remove(validation_path)
FileNotFoundError: [Errno 2] No such file or directory: ‘/var/www/tswi.gaming-evolution.net/.well-known/acme-challenge/kE4EAUQZgDCCJ0RU_DjFX88G28Hu90LQ_nehrJCOAKk’
Attempting to renew cert (tswi.gaming-evolution.net) from /etc/letsencrypt/renewal/tswi.gaming-evolution.net.conf produced an unexpected error: [Errno 2] No such file or directory: ‘/var/www/tswi.gaming-evolution.net’. Skipping.
/etc/letsencrypt/live/gaming-evolution.net/fullchain.pem (failure)
/etc/letsencrypt/live/tswi.gaming-evolution.net/fullchain.pem (failure)
/etc/letsencrypt/live/ranksystem.gaming-evolution.net/fullchain.pem expires on 2020-02-14 (skipped)
/etc/letsencrypt/live/teamspeak.gaming-evolution.net/fullchain.pem expires on 2020-02-12 (skipped)
2 renew failure(s), 0 parse failure(s)
Domain: gaming-evolution.net
Detail: Invalid response from
content=“IE=edge”>\n "To fix these errors, please make sure that your domain name was
My web server is (include version): Nginx 1.10.3
My hosting provider, if applicable, is: Hetzner
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
