Hello,
I am in trouble about renewing multidomain 1 level wildcard for 12 domains.
(Maybe this is a cerbot question)
When certbot started evetthing goes well but it is not asking for 24 only 15 dns txt edits.
Then fails (propagate time may not be inof its ok) but
Question is ;Should certbot ask 24 or 15 is fine to update cert?
certbot certificates command result is like below
Found the following certs:
Certificate Name: internetebak.com
Serial Number: 3de6302d2760845d86105c16b7d10daxxxx
Key Type: ECDSA
Domains: arabamibul.net *.arabamibul.net *.ariyoruz.net *.bakiyoruz.net *.bulonline.com *.dogaldukkan.net *.evarkadasiara.net *.internetebak.com *.kiraciara.com *.kiraciara.net *.kiralikbul.net *.temizikinciel.net *.yemekkultur.com ariyoruz.net bakiyoruz.net bulonline.com dogaldukkan.net evarkadasiara.net internetebak.com kiraciara.com kiraciara.net kiralikbul.net temizikinciel.net yemekkultur.com
Expiry Date: 2024-11-28 10:17:48+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/internetebak.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/internetebak.com/privkey.pem
certbot certonly --manual --email kanpinar@gmail.com --preferred-challenges=dns --server https://acme-v02.api.letsencrypt.org/directory --agree-tos -d arabamibul.net -d *.arabamibul.net -d ariyoruz.net -d *.ariyoruz.net -d bakiyoruz.net -d *.bakiyoruz.net -d bulonline.com -d *.bulonline.com -d dogaldukkan.net -d *.dogaldukkan.net -d evarkadasiara.net -d *.evarkadasiara.net -d internetebak.com -d *.internetebak.com -d kiraciara.com -d *.kiraciara.com -d kiraciara.net -d *.kiraciara.net -d kiralikbul.net -d *.kiralikbul.net -d temizikinciel.net -d *.temizikinciel.net -d yemekkultur.com -d *.yemekkultur.com
Renewing an existing certificate for arabamibul.net and 23 more domains
Nginx .Net Core
Debian 12
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): ssh
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
