My domain is: manna167995195books.com.ng
I ran this command: certbot renew --cert-name manna167995195books.com.ng
It produced this output: All renewal attempts failed the following certificate could not be renewed
Ubuntu 18.04.2 x64
Ubuntu 18.04.2 x64
My hosting provider, if applicable, is: Digitalocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, putty
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):0.31.0
The “failed authorizations” rate limit will reset in an hour. And if you’d use SSH to connect to your server rather than Digital Ocean’s console, you’d be able to copy/paste.
Hi JuergenAuer,
Thanks for your reply. I tried and couldn’t get in touch with the developer that installed the certificate to remove the redirection.
I would be grateful for some direction on how this redirection was created and how to remove it.
Thanks once again for your assistance.
