Renewal problem
mikmer.fr or www.mikmer.fr
certbot renew
http-01 challenge for mikmer.fr
http-01 challenge for www.mikmer.fr
Attempting to renew cert (mikmer.fr) from /etc/letsencrypt/renewal/mikmer.fr.conf produced an unexpected error: Missing command line flag or config entry for this setting:
Input the webroot for mikmer.fr:. Skipping.
Apache/2.4.29 (Ubuntu)
Ubuntu 18.04.3 LTS
Yes
certbot 0.31.0
Here is the content of my .conf file
<VirtualHost *:80>
DocumentRoot /var/www/html/wordpress
ServerName mikmer.fr
ServerAlias www.mikmer.fr
RewriteEngine on
RewriteRule ^.well-known - [L]
Redirect permanent / https://www.mikmer.fr/
<VirtualHost *:443>
<Directory “/var/www/html/wordpress”>
Options -Indexes
Order allow,deny
Allow from all
AllowOverride FileInfo
Require all granted
SSLCertificateFile /etc/letsencrypt/live/mikmer.fr/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mikmer.fr/privkey.pem
Header always set Content-Security-Policy "default-src https: data: ‘unsafe-inline’ 'unsafe-eval$
Header always set Feature-Policy "geolocation ‘none’; midi ‘none’; camera ‘none’; usb ‘none’; ma$
Header always set Referrer-Policy “same-origin”
ErrorLog /var/log/apache2/wp.error.log
CustomLog /var/log/apache2/wp.access.log combined
I tried to find an answer in the forum without succes…
Any help would be appreciated :slight_smile:
Due to a bug fixed in a later version of Certbot, /etc/letsencrypt/renewal/mikmer.fr.conf is missing your web root path setting.
Manually specifying it with “certbot renew -w /var/www/html/wordpress” – or whatever the path is – may work.
If not, try running the command you used to create the certificate originally, e.g. “certbot certonly --webroot -d mikmer...”.
Thanks a lot mnordhoff : it works with -w option !
