Renewal problem Nginx Debian
1wise.es labirreria.es webbingteam.com
certbot --nginx
1: 1wise.es
2: www.1wise.es
3: labirreria.es
4: www.labirreria.es
5: webbingteam.com
6: www.webbingteam.com
blank to select all options shown (Enter ‘c’ to cancel):
çAttempting to parse the version 0.33.1 renewal configuration file found at /etc/letsencrypt/renewal/1wise.es.conf with version 0.11.1 of Certbot. This might not work.
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
nginx version: nginx/1.14.2
debian 10 buster
ovh
no
a mess
-certbot 0.11.1
-certbot-auto --version
Error: couldn’t get currently installed version for /opt/eff.org/certbot/venv/bin/letsencrypt:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 7, in
from certbot.main import main
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 6, in
import logging.handlers
File “/usr/lib/python2.7/logging/init.py”, line 26, in
import sys, os, time, cStringIO, traceback, warnings, weakref, collections
File “/usr/lib/python2.7/weakref.py”, line 14, in
from _weakref import (
ImportError: cannot import name _remove_dead_weakref
What do “which certbot” and “sudo which certbot” show?
How is Certbot installed?
Are you really running Debian 10?
The packaged version of Certbot is 0.31.0.
As for the certbot-auto error, I’d suggest renaming or deleting /opt/eff.org/certbot/ so it will reinstall itself. The installation might be broken if you did something like upgrade from an earlier version of Debian.
Server was upgraded from jessie to buster previously to this error, I :
pip install --upgrade acme
pip install --upgrade certbot-nginx
and
certbot --nginx
went fluid
SOLVED !!!
