My domain is: sevenburg.com
I ran this command: certbot --nginx-ctl /usr/sbin/nginx renew --force-renew --quiet --nginx --renew-hook "/etc/init.d/nginx reload"
It produced this output: Attempting to renew cert (sevenburg.com) from /etc/letsencrypt/renewal/sevenburg.com.conf produced an unexpected error: None of the preferred challenges are supported by the selected plugin. Skipping.
/etc/letsencrypt/live/sevenburg.com/fullchain.pem (failure)
My web server is (include version): nginx 1.22.0
The operating system my web server runs on is (include version): Debian 10
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
PS: crontab worked fine but this time an error occurs.
-rw-r--r-- 1 root root 1858 Jun 3 21:26 cert1.pem
-rw-r--r-- 1 root root 1862 Jun 5 02:31 cert2.pem
-rw-r--r-- 1 root root 1862 Jun 12 02:33 cert3.pem
-rw-r--r-- 1 root root 1785 Jun 19 02:36 cert4.pem
-rw-r--r-- 1 root root 1781 Jun 26 02:30 cert5.pem
-rw-r--r-- 1 root root 3750 Jun 3 21:26 chain1.pem
-rw-r--r-- 1 root root 3750 Jun 5 02:31 chain2.pem
-rw-r--r-- 1 root root 3750 Jun 12 02:33 chain3.pem
-rw-r--r-- 1 root root 3750 Jun 19 02:36 chain4.pem
-rw-r--r-- 1 root root 3750 Jun 26 02:30 chain5.pem
-rw-r--r-- 1 root root 5608 Jun 3 21:26 fullchain1.pem
-rw-r--r-- 1 root root 5612 Jun 5 02:31 fullchain2.pem
-rw-r--r-- 1 root root 5612 Jun 12 02:33 fullchain3.pem
-rw-r--r-- 1 root root 5535 Jun 19 02:36 fullchain4.pem
-rw-r--r-- 1 root root 5531 Jul 10 00:50 fullchain5.pem
-rw------- 1 root root 1704 Jun 3 21:26 privkey1.pem
-rw------- 1 root root 1708 Jun 5 02:31 privkey2.pem
-rw------- 1 root root 1708 Jun 12 02:33 privkey3.pem
-rw------- 1 root root 1704 Jun 19 02:36 privkey4.pem
-rw------- 1 root root 1708 Jun 26 02:30 privkey5.pem
configuration file:
renew_before_expiry = 30 days
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/sevenburg.com
cert = /etc/letsencrypt/live/sevenburg.com/cert.pem
privkey = /etc/letsencrypt/live/sevenburg.com/privkey.pem
chain = /etc/letsencrypt/live/sevenburg.com/chain.pem
fullchain = /etc/letsencrypt/live/sevenburg.com/fullchain.pem
[renewalparams]
account = (number),
pref_challs = dns-01,
authenticator = nginx
renew_hook = /etc/init.d/nginx reload
installer = nginx
nginx_ctl = /usr/sbin/nginx
