Renewal not working
My domain is: cldsl.ca
I ran this command: cerfiticate renewal
It produced this output: 2019-07-30 08:57:49.585 -05:00 [INF] Checking automated challenge response for Domain: mail.cldsl.ca
2019-07-30 08:57:50.903 -05:00 [INF] Invalid response from http://mail.cldsl.ca/.well-known/acme-challenge/p6tbOUP9fCeCRpP9l-qqk-nOYdjVSWLs6EybM0fUIeI [67.226.238.52]: "\r\n<html xmlns=“http”
2019-07-30 08:57:52.761 -05:00 [INF] Validation of the required challenges did not complete successfully. Invalid response from http://mail.cldsl.ca/.well-known/acme-challenge/p6tbOUP9fCeCRpP9l-qqk-nOYdjVSWLs6EybM0fUIeI [67.226.238.52]: "\r\n<html xmlns=“http”
2019-07-30 09:25:52.074 -05:00 [INF] Previous renewals failed: 25. Renewal will be attempted within 48hrs.
2019-07-30 09:26:17.305 -05:00 [INF] Previous renewals failed: 25. Renewal will be attempted within 48hrs.
My web server is (include version): IIS 7
The operating system my web server runs on is (include version): Server 2008 R2
My hosting provider, if applicable, is: selft hosted
Hi @kernal
checking your domain there is one older certificate ( https://check-your-website.server-daten.de/?q=mail.cldsl.ca#ct-logs ):
Let's Encrypt Authority X3 2019-06-17 2019-09-15 cldsl.ca, mail.cldsl.ca, www.cldsl.ca - 3 entries
Are there any configuration changes between 2019-06-17 and now?
You use an IIS: Find the webroot of your subdomain, create the two subdirectories
there a file (file name 1234 without extension), then try to load that file via
 http://mail.cldsl.ca/.well-known/acme-challenge/1234
and use the online tool to check that file.
The error message is "only" an internal pre-check, not the result of the Letsencrypt check.
Perhaps you have some wrong local dns entries.
