Renewal Issues - Unauthorized?
My domain is: https://in-spired.xyz
root@localhost:/var/www/in-spired.xyz/.well-known# certbot renew
Processing /etc/letsencrypt/renewal/in-spired.xyz.conf
Plugins selected: Authenticator webroot, Installer nginx
Renewing an existing certificate for in-spired.xyz and www.in-spired.xyz
http-01 challenge for in-spired.xyz
http-01 challenge for www.in-spired.xyz
Challenge failed for domain in-spired.xyz
Challenge failed for domain www.in-spired.xyz
Failed to renew certificate in-spired.xyz with error: Some challenges have failed.
  /etc/letsencrypt/live/in-spired.xyz/fullchain.pem (failure)
   Domain: in-spired.xyz
   Type:   unauthorized
   Detail: Invalid response from
   https://in-spired.xyz/.well-known/acme-challenge/-u0cowwidemvyvh2cncjyjz5hwtlsvqe743-himoezq/
   [139.162.201.166]: "<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n\n
   <meta charset=\"utf-8\" />\n    <meta
   http-equiv=\"X-UA-Compatible\" content=\"IE=edge\" /"
   Domain: www.in-spired.xyz
   Type:   unauthorized
   https://www.in-spired.xyz/.well-known/acme-challenge/hvbo6ommlsoleypj46cnzsj11x2ejbtiweiaavvik-e/
My web server is (include version): Nginx 1.18
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Linode
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.12.0
Not really sure what's changed, as I was able to add the certificate fine originally. I'm in a bit of a muddle as I used Run your blog with Ghost, Docker and LetsEncrypt to create the platform, and using docker is kind of confusing me a little bit as to where everything is getting put. If I run certbot renew -a nginx --dry-run it seems to succeed, so I'm unsure why it won't work normally, runs out in 5 days.
Thanks for any help, I really appreciate any time given.
Some additional information.
Nginx Configuration
root@localhost:/var/www/in-spired.xyz/.well-known# cat /etc/nginx/conf.d/default
        listen 80;
        server_name in-spired.xyz;
        location /.well-known/ {
                root /var/www/in-spired.xyz/.well-known/;
                return 301 https://$server_name$request_uri;
        listen 443 ssl;
                proxy_pass      http://127.0.0.1:2368;
                proxy_set_header    X-Real-IP $remote_addr;
                proxy_set_header    Host      $http_host;
                proxy_set_header X-Forwarded-Proto https;
        ssl_certificate     /etc/letsencrypt/live/in-spired.xyz/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/in-spired.xyz/privkey.pem;
        ssl on;
Does this command show any warnings?
sudo nginx -t
Based on how your server behaves I suspect you have some duplicate virtual hosts in nginx.
Thanks for your reply.
This is the response to that command, there doesn't appear to be any issues in my Nginx configuration. I copied it word for word from that blog I've linked when setting it up with Ghost and Docker.
I've only got the "default" site in my Nginx which is my site.
root@localhost:/etc/nginx/sites-enabled# ls -la
total 8
drwxr-xr-x 2 root root 4096 Jan 31 18:09 .
drwxr-xr-x 8 root root 4096 Feb 15 18:30 ..
lrwxrwxrwx 1 root root   34 Jan 31 18:09 default -> /etc/nginx/sites-available/default
Edit: blah, I am blind. It's right there in your original post:
You originally set up this to renew with the webroot authenticator. If you change it to nginx:
it should succeed, and permanently save the new authenticator for next time.
Oh jeez, weeks I've been pulling my hair out over this trying to workout where my docker web root is and fighting with this. Thank you so much :smile:
