Up until recently, it has been updating automatically via crontab without any problems. Recently, it stopped working with “Connection refused”. The server is clearly reachable.
crontab ran:
/usr/bin/letsencrypt renew
Processing /etc/letsencrypt/renewal/pydio.rainexpected.com.conf
http-01 challenge for droopy.rainexpected.com
http-01 challenge for pydio.rainexpected.com
http-01 challenge for s.rainexpected.com
Waiting for verification…
Attempting to renew cert (pydio.rainexpected.com) from /etc/letsencrypt/renewal/pydio.rainexpected.com.conf produced an unexpected error: Failed authorization procedure. s.rainexpected.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://s.rainexpected.com/.well-known/acme-challenge/Wx7Is1eBk6I9PhmaGTQqItxl5YZqePjysBZEHkOrHh4: Connection refused, droopy.rainexpected.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://droopy.rainexpected.com/.well-known/acme-challenge/fxrHL7K3Of6HUcLqjoCPMVxbjrA0LB7rBK4pFiOtezQ: Connection refused, pydio.rainexpected.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://pydio.rainexpected.com/.well-known/acme-challenge/jw4G9OKMqo0-ro5JE06z704zaNN7Y9ypJB-MiXQhPug: Connection refused. Skipping.
/etc/letsencrypt/live/pydio.rainexpected.com/fullchain.pem (failure)
Domain: pydio.rainexpected.com
Type: connection
Detail: Fetching
Connection refusedTo fix these errors, please make sure that your domain name was
Apache 2.4.25-3+deb9u6
Debian stretch
Yes
No
