My domain is: dev.stephane-huc.net
I ran this command: certbot renew --cert-name dev.stephane-huc.net --dry-run
Processing /etc/letsencrypt/renewal/dev.stephane-huc.net.conf
http-01 challenge for dev.stephane-huc.net
Unable to clean up challenge directory /srv/www/dev.stephane-huc.net/www/.well-known/acme-challenge
Attempting to renew cert from /etc/letsencrypt/renewal/dev.stephane-huc.net.conf produced an unexpected error: Failed authorization procedure. dev.stephane-huc.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://dev.stephane-huc.net/.well-known/acme-challenge/4u3UDymEci7--oXKHkHnNMi3dFUxIdmielM_IW-zR3o: Timeout. Skipping.
/etc/letsencrypt/live/dev.stephane-huc.net/fullchain.pem (failure)
Domain: dev.stephane-huc.net
Type: connection
Detail: Fetching
Timeout
My web server is (include version): Nginx (1.12.0-1)
The operating system my web server runs on is (include version): Ubuntu Xenial
My hosting provider, if applicable, is: @home
I resolved error 404. (https://dev.stephane-huc.net/.well-known/acme-challenge/test <= success)
If i watch the directory 'acme-challenge' by 'watch -n1 ls', i seen the file created and deleted.
If i attempt with letsencrypt tool (updated by git), i've another error.
Command: /opt/letsencrypt/letsencrypt-auto certonly --renew-by-default --config "${file_cfg_le}"
File config content:
# Prefer to use a 4096 bit RSA key instead of 2048
rsa-key-size = 4096
email = webmaster@stephane-huc.net
domains = dev.stephane-huc.net
authenticator = webroot
# This is the webroot directory of your domain in which
# letsencrypt will write a hash in /.well-known/acme-challenge directory.
webroot-path = /srv/www/dev.stephane-huc.net/www/
The output:
Using the webroot path /srv/www/dev.stephane-huc.net/www for all unmatched domains.
Failed authorization procedure. dev.stephane-huc.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to dev.stephane-huc.net
Type: connection
Detail: Could not connect to dev.stephane-huc.net
But both commands launched with rights root!
