Renewal "Connection Refused"
I’ve read in a forum that Comcast may block port 80 even though it is not an officially blocked port (i.e., if they discover that one is running a web site). Is there any way to change the port that letsencrypt uses to authenticate sites? And I think I may need to do some work to get port forwarding working on ipv6.
No, that’s not it. I installed tcpdump on my router and it is seeing attempts to reach port 80. I have a port forward set up but for some reason it is not getting to the server.
Not really.
Only other (simple) option is DNS authentication.
Do you have a firewall on your server?
No, nothing but iptables and one rule: 0 0 SNAT all -- * * 10.8.0.0/24 0.0.0.0/0 to:76.100.171.177.
Many thanks for all your help. I used DNS authentication for until I can figure out what is going on with my network. I know it used to work and now it doesn’t. What happened, I can’t figure.
Let’s see which ports are in use
Please show:
sudo netstat -pant
Here is what it looks like now:
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      255/rpcbind
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      23832/sshd
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      886/exim4
tcp        0      0 127.0.0.1:9050          0.0.0.0:*               LISTEN      494/tor
tcp        0      0 127.0.0.1:9051          0.0.0.0:*               LISTEN      494/tor
tcp        0      0 127.0.0.1:4200          0.0.0.0:*               LISTEN      398/shellinaboxd
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      487/mysqld
tcp6       0      0 :::111                  :::*                    LISTEN      255/rpcbind
tcp6       0      0 :::80                   :::*                    LISTEN      5356/apache2
tcp6       0      0 :::22                   :::*                    LISTEN      23832/sshd
tcp6       0      0 ::1:25                  :::*                    LISTEN      886/exim4
tcp6       0      0 :::443                  :::*                    LISTEN      5356/apache2
Well it shows that apache2 is listening on 80 and 443 for both IPv4 and IPv6.
However, I am only able to connect to IPv4 on port 80 (all others show “Connection refused”) and it merely returns:
<?xml version="1.0" encoding="UTF-8"?><tree ><require_auth/></tree>
So, I can only assume that the problem is within the Apache configuration (or .htaccess).
Or perhaps you IP has changed.
Ugh. Some of the Openwrt web interface uses javascript and I had thought that I had fixed a configuration problem. But when I told it to reboot, it didn’t really reboot. After ssh’ing into the router and issuing a reboot command, it actually rebooted and now my fix worked and I can get to ipv4 on both ports 80 and 443. I think ipv6 is still broken.
Using tcpdump I can see that the router is definitely seeing ipv6 requests on ports 80 and 443 but they’re just not being passed onto the server.
You could remove the IPv6 (AAAA) DNS entries.
Issue your cert.
Then work on the IPv6 problem.
Thank you! I figured out a traffic rule on the router that forwards traffic to the correct IPv6 address so it should all be good now.
