Renew is not working
My domain is: admissionschool.com
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/admissionschool.com.conf
Plugins selected: Authenticator apache, Installer None
http-01 challenge for admissionschool.com
http-01 challenge for www.admissionschool.com
Waiting for verification…
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/admissionschool.com/fullchain.pem
/etc/letsencrypt/live/admissionschool.com/fullchain.pem (success)
Still I am getting SSL error on browser
Plase help me to resolve this
Thanks
There are a few things worth noticing:
  1. You used certbot renew --dry-run, which would going to simulate the renewal, but not actually renew the certificate.
  1. You might need to reload your webserver after renewal, see the below quote.
Solution:
Run sudo certbot renew and check if the new certificate is issued and showed up on browsers. If not, you'll also need to manually reload your webserver.
Thank you
Thanks for a quick solution.
It worked
