Certificate renew issue
My domain is: [redacted]
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/[redacted].conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for subdomain1.[redacted]
http-01 challenge for [redacted]
http-01 challenge for subdomain2.[redacted]
Using default addresses 80 and [::]:80 ipv6only=on for authentication.
Waiting for verification…
new certificate deployed with reload of nginx server; fullchain is
/etc/letsencrypt/live/[redacted]/fullchain.pem
/etc/letsencrypt/live/[readacted]/fullchain.pem (success)
** (The test certificates above have not been saved.
My hosting provider, if applicable, is: nginx
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.26.1
Initially i installed certificate through - certbot --nginx certonly --cert-name [redacted]
following command
Your test run was successful. What exactly is the problem you're running into?
That is just a test.
This seems to indicate that you actually need to renew them now for real:
So did they renew or just test renew?
Please show:
certbot certificates
certonly doesn't modify the config...
[it literally ONLY gets a CERT]
Thanks, I m not able to see changes in expiry date after nginx service reload.
So what happended exactly certificate renewed or not
Probably NOT: crt.sh | [redacted]
To confirm, please show output of:
When I am checking my certificate expiry
Command written in [redacted] folder
openssl x509 -dates -noout -in fullchain.pem
notBefore=Nov 29 04:03:57 2018 GMT
notAfter=Feb 27 04:03:57 2019 GMT
This time is not changing here after nginx
reload
This command would be much simpler...
But they should show the same date: 2019.02.27 [21 days from now]
So it seems the command:
Did exactly that; Just a --dry-run TEST.
You need to repeat that without the --dry-run testing.
Try:
certbot renew
Did you also run certbot renew without the --dry-run?
Did you point your nginx configuration file to the symbolic links in /etc/letsencrypt/live/{yourhostname}/?
i havent tried certbot renew will check
/etc/letsencrypt/live/{yourhostname}/ ?
This i have done
