tls-sni-01 challenge for www.clarksclater.com
Attempting to renew cert (www.clarksclater.com) from /etc/letsencrypt/renewal/www.clarksclater.com.conf produced an unexpected error: Problem binding to port 443: Could not bind to IPv4 or IPv6… Skipping.
/etc/letsencrypt/live/www.clarksclater.com/fullchain.pem (failure)
My web server is (include version): Ubuntu 14.04.5 LTS (GNU/Linux 3.13.0-135-generic x86_64)
The operating system my web server runs on is (include version): macOS Sierra 10.12.24
My hosting provider, if applicable, is: AWS -EC2
I searched around and see others had same/similiar issues. I couldn’t find a solution. The ports 80 & 443 seem tied up with other services. I run a simple static wordpress site on the server if that matters at all. I appreciate any help in getting my certificate renewed.
Your certbot recorded that you obtained the certificate using TLS-SNI-01, which is depreciated (due to security). You can try run the command certbot renew --preferred-challenges http and use http challenges or change http to webroot, which ever worked for you.
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: argument --preferred-challenges: Unrecognized challenges: webroot
Is this what you were suggesting? I had tried the http before and got the error for port 80
You’re using the standalone authenticator, which won’t work while other services are running on port 80 (in some situations it can use port 443, but as stevenzhu mentioned that’s deprecated and you shouldn’t rely on it; it doesn’t seem to help in your case anyway).
Your server seems to be running Apache, right? In that case you might try:
certbot renew --authenticator apache
If that doesn’t work, update certbot to the latest version and try again. If you can’t do that, you may need to start over and use the webroot method (certbot certonly --webroot etc).
Another option is to temporarily stop Apache while you do the renewal.
1: Apache Web Server plugin - Beta (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 3
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): www.clarksclater.com
http-01 challenge for www.clarksclater.com
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. www.clarksclater.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.clarksclater.com/.well-known/acme-challenge/sBSglSIfru53XIxBHT7Orxk0T2GxCf5hwtxbrS7925k: "
It's probably the directory where Wordpress is installed. Or you can check your Apache configuration and find the DocumentRoot. As a test, try placing a file in that directory and see if you can access it in your browser.
So, something along the lines of
certbot certonly --webroot -w /var/www/wordpress
replacing /var/www/wordpress with whatever the directory is. You might also want to add a --deploy-hook to reload Apache after renewing as well:
Failed authorization procedure. www.clarksclater.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.clarksclater.com/.well-known/acme-challenge/sBSglSIfru53XIxBHT7Orxk0T2GxCf5hwtxbrS7925k: 1 "
<meta name="viewport" content"
Do I need to update the DNS for authentication? Where can I find the documentation for this?
Try putting a file there, eg /var/www/html/test.txt - can you then see that file at http://www.clarksclater.com/test.txt (skipping any certificate warnings) in a web browser?
If not, /var/www/html is not correct and you’ll need to find the correct webroot directory.
I appreciate your help. Are there any commands you can recommend for me to see the entire directory of files? I should have full access to anything I need to get to in order to find out the information required.
(note the capital S) to get an overview of your Apache configuration and where the configuration is for everything. Then look in the file containing the virtual host configuration for your domain, and see if you can find the DocumentRoot.
I deployed Bitnami Wordpress if that matters as you will see a list of some files below. As you can probably tell, I’m not really sure exactly what I’m looking for. Could any of these be it?
By the way, I know that you eventually got things working another way, but I wanted to point out that --preferred-challenges webroot is different from --preferred-challenges http (which @stevenzhu suggested to you). In Certbot terminology, HTTP-01 is a challenge type and webroot is a plugin (which implements the HTTP-01 challenge type). So, --preferred-challenges webroot doesn't identify a valid challenge type to Certbot.
