kriebel.mooo.com
sudo certbot renew
Processing /etc/letsencrypt/renewal/kriebel.mooo.com.conf
Renewing an existing certificate for kriebel.mooo.com
Domain: kriebel.mooo.com
Type: connection
Detail: 2a00:6020:a583:b000:6b4a:4b95:e3fc:5be9: Fetching http://kriebel.mooo.com/.well-known/acme-challenge/xxxx: Error getting validation dataHint: The Certificate Authority failed to download the challenge files from the temporary standalone webserver started by Certbot on port 80. Ensure that the listed domains point to this machine and that it can accept inbound connections from the internet.
Failed to renew certificate kriebel.mooo.com with error: Some challenges have failed.
/etc/letsencrypt/live/kriebel.mooo.com/fullchain.pem (failure)
My web server is:
apache2 -v
Server version: Apache/2.4.59 (Raspbian)
Server built: 2024-04-05T12:08:04
lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
It is my own local server (raspberry pi) behind a router
I can login to a root shell on my machine:
I'm using a ssh terminal to connect to the RPi
The version of my client is:
certbot --version
certbot 2.8.0
Additonal Info:
I guess this is an IPV6 issue with certbot in standalone mode.
I have a new provider which uses CGNAT for 6 weeks now. Since then I have this issue. Before, with the old provider and dynamic IPV4, certbot was running fine.
I have an working entry for kriebel.mooo.com at freedns, my apache2 webiste running on my RPI which can be successfully accessed from outside, i.e. if you call https://kriebel.mooo.com, you'll see "Hello world" from my server. To my view that proves that the RPI can be accessed via IPV6 and that DNS offers the correct IP.
In the letsencrypt.log I found these suspicious lines:
2024-07-24 16:19:38,998:INFO:certbot._internal.auth_handler:Performing the following challenges:
2024-07-24 16:19:38,999:INFO:certbot._internal.auth_handler:http-01 challenge for kriebel.mooo.com
2024-07-24 16:19:39,001:DEBUG:acme.standalone:Successfully bound to :80 using IPv6
2024-07-24 16:19:39,002:DEBUG:acme.standalone:Certbot wasn't able to bind to :80 using IPv4, this is often expected due to the dual stack nature of IPv6 socket implementations.
I don't know how to convince certbox to use IPV6.
My renewal params are
[renewalparams]
account = xxxxxxxxx
authenticator = standalone
key_type = ecdsa
