Renewing an existing certificate for www.ingber.com and 6 more domains
ingber.com
/usr/bin/certbot renew
Processing /etc/letsencrypt/renewal/www.ingber.com.conf
  Domain: blog.ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://blog.ingber.com/.well-known/acme-challenge/r07W_zUeK6qjz7g0e0lr-nWjN8Ukm7mlJBXTWAz6lmI: Timeout during connect (likely firewall problem)
  Domain: default.ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://default.ingber.com/.well-known/acme-challenge/vbdlFjN30s4nTlTOheXtGqLWBUo-XBRHmym95woR_Js: Timeout during connect (likely firewall problem)
  Domain: ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://ingber.com/.well-known/acme-challenge/SCCzTv68p2l0GLFmqFyCQzsEvGEIh0mxZ7gKjG9xQB0: Timeout during connect (likely firewall problem)
  Domain: lin.ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://lin.ingber.com/.well-known/acme-challenge/AJnNnen348eYRrG7PhLx3At400FNJQG3VaoQ26eY6tM: Timeout during connect (likely firewall problem)
  Domain: www.ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://www.ingber.com/.well-known/acme-challenge/U1cHHs4HUnwy60xgMt47KAsIHxaShahf0dEHxZ7eAzw: Timeout during connect (likely firewall problem)
  Domain: lester.ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://lester.ingber.com/.well-known/acme-challenge/VtPetkQYmbKgsKfZhYRHwxeJGXJIXj44I2KcCHgK3T8: Timeout during connect (likely firewall problem)
  Domain: lin6.ingber.com
  Type:   connection
  Detail: 173.255.212.226: Fetching https://lin6.ingber.com/.well-known/acme-challenge/6POFwd9NhaB9wSE8xqBBOeZG6viv3vZer0BldiI5JLw: Timeout during connect (likely firewall problem)
Failed to renew certificate www.ingber.com with error: Some challenges have failed.
  /etc/letsencrypt/live/www.ingber.com/fullchain.pem (failure)
ingber.com
Linux lin 5.15.0-60-generic #66-Ubuntu SMP Fri Jan 20 14:29:49 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Linode.com VPS
no
certbot 2.5.0
Hello @, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using the online tool Let's Debug I see several ERRORs https://letsdebug.net/ingber.com/1439605
All your IP Addresses (both IPv4 and IPv6) need to be able to respond to the HTTP-01 Challenge on Port 80.
looks like you didn't open port 80: keep mind LE doesn't care about HSTS:
from letsdebug:
The failed /var/log/letsencrypt/letsencrypt.log is attached.
letsencrypt.log
that's link to some ramdom thread, not file
Using this online tool https://www.redirect-checker.org/ with http://ingber.com/.well-known/acme-challenge/sometestfile as the input yields these results
HTTP Headers
> 302 Found
Status:	302 Found
Code:	302
Date:	Sun, 09 Apr 2023 18:21:04 GMT
Server:	Apache
Location:	https://ingber.com/.well-known/acme-challenge/sometestfile
Content-Length:	242
Connection:	close
Content-Type:	text/html; charset=iso-8859-1
> 403 Forbidden
Status:	403 Forbidden
Code:	403
Date:	Sun, 09 Apr 2023 18:21:05 GMT
Server:	Apache
Content-Length:	318
Connection:	close
Or for those who prefer more visual view
@lingber Your IPv6 is broken again. Also, have you reviewed your past threads to ensure an old problem has not resurfaced?
nslookup www.ingber.com
Address: 173.255.212.226
Address: 2600:3c01::f03c:91ff:fe93:e6f3
curl -i6 https://www.ingber.com/.well-known/acme-challenge/Test123
curl: (28) Failed to connect to www.ingber.com port 443 after 130349 ms: Connection timed out
Here is an online tool to do DNS https://unboundtest.com/ configured very similarly to Let's Encrypt's production servers, and is started fresh for each query so there are no caching effects. With a choice of Query type: CAA A AAAA TXT
Hi. Yes, I see a ping to that address fails. That IPv6 was valid for a long time and I suspect Akamai purchase of Linode may have something to do with this problem?
I have contacted their support re a valid IPv6 address. I assume that is the only problem you see, e.g., my IPv4 address is responding correctly?
Thanks.
Lester
Note that I am using Cloudflare's IPv4 and IPv6 for their security.
I believe so; it visually looks right to me on Windows 10 with Chrome and Firefox; plus curl seems fine too.
~$ curl -4 -Ii https://ingber.com/
HTTP/1.1 302 Found
Date: Sun, 09 Apr 2023 20:42:41 GMT
Server: Apache
$ curl -4 -Ii https://www.ingber.com/
HTTP/1.1 200 OK
Date: Sun, 09 Apr 2023 20:42:48 GMT
Server: Apache
Accept-Ranges: bytes
Vary: Accept-Encoding
Content-Length: 133650
Can I get by with just an IPv4 address?
I don't see Cloudflare involved at all. At least not with domain www.ingber.com
I see the IPv4 attached to Linode (not Cloudflare)
Yes, IPv6 is not required. In the past your server configs were highly specific to IPv4 and IPv6 so I'm not sure what impact these have since you may have made changes since.
Somewhat a decision for you based off of what/who and how they will connect yo your web server.
I only have IPv4.
I reset my DNS on Linode.com to just use my IPv4 address, but I still get failures?
I don't know IPv6 is your only problem. But, at least for ingber.com I still see an AAAA record in your authoritive servers (I didnt check them all)
https://unboundtest.com/m/AAAA/ingber.com/MQRWU2RR
Now, all are failing?
Most likely: Yes.
I still see:
Addresses: 2600:3c01::f03c:91ff:fe93:e6f3
           173.255.212.226
           173.255.212.226
I believe that now my reset to use IPv4 only is working OK. I just rebooted my Linode after resetting everything (I think?) to IPv4.
Thanks.
Lester
The TTL hasn't expired yet; So, some DNS caches will still show the IPv6 address.
