My domain is: lendercore.rupeek.co
I ran this command: /usr/bin/certbot renew --renew-hook "/usr/local/bin/renew.sh".
We've created a script which check every hour and renews the SSL if its gonna expire.
"IMPORTANT NOTES:
** - The following errors were reported by the server:**
** Domain: lendercore.rupeek.co**
** Type: connection**
** Detail: 15.206.120.231: Fetching**
** http://lendercore.rupeek.co/.well-known/acme-challenge/j6W6JJLjOzs5ptsVDy8wHnlG4xKUnQO56bzL1LYwCyU:**
** Connection refused**
** To fix these errors, please make sure that your domain name was**
** entered correctly and the DNS A/AAAA record(s) for that domain**
** contain(s) the right IP address. Additionally, please check that**
** your computer has a publicly routable IP address and that no**
** firewalls are preventing the server from communicating with the**
** client. If you're using the webroot plugin, you should also verify**
** that you are serving files from the webroot path you provided.**
** Type: serverInternal**
** Detail: During secondary validation: Remote PerformValidation RPC**
** failed**
** Unfortunately, an error on the ACME server prevented you from**
** completing authorization. Please try again later.**
** failed**
** completing authorization. Please try again later."**
My web server is (include version): HA-Proxy version 1.8.8-1ubuntu0.13
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
My hosting provider, if applicable, is: AWS Route 53
or certbot-auto --version
if you're using Certbot): certbot 0.31.0
