Redirected to an unreachable https webpage (timeout)
My domain is: multital.inalco.fr
Since I ran sudo certbot --apache the http page is redirected to https but the page fails dut to a timeout
Also:
Produced this output:
Assessment failed: Unable to connect to the server
I also checked https://check-your-website.server-daten.de/?q=multital.inalco.fr
And I've found no where a mention of port 443 only 8443
|Domain |IP |Port|Cert.|
|multital.inalco.fr|multital.inalco.fr|8443|name does not match|
193.51.82.102|193.51.82.102|8443|name does not match
I read several discussions of the community related to my problem but I didn't mange to find a solution.
My web server is (include version): apache2
The operating system my web server runs on is (include version): centos 7
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.9.0
Here is the http config file:
<VirtualHost *:80>
    ServerName multital_wsgi
   # WSGIDaemonProcess main user=adrien group=adrien python-eggs=/var/www/multital_env/python_egg_cache  python-path=/var/www/multital_env/lib/python2.7/site-packages processes=3 threads=5
    #WSGIDaemonProcess store user=adrien group=adrien python-eggs=/var/www/multital_env/python_egg_cache  python-path=/var/www/multital_env/lib/python2.7/site-packages processes=3 threads=5
    WSGIApplicationGroup %{GLOBAL}
    WSGIProcessGroup main
    WSGIScriptAlias / /var/www/multital_env/multital/wsgi/app.wsgi
    <Location /store>
    WSGIProcessGroup store
    </Location>
    #allow access to directory where .wsgi script is found
    <Directory /var/www/multital_env/multital/wsgi>
    Require all granted
    </Directory>
    #Serve static files directly without TurboGears
    Alias /img /var/www/multital_env/multital/multital/public/img
    Alias /css /var/www/multital_env/multital/multital/public/css
    Alias /javascript /var/www/multital_env/multital/multital/public/javascript
    Alias /fonts /var/www/multital_env/multital/multital/public/fonts
    Alias /readme /home/adrien/multital_readme_html
    Alias /medias /home/adrien/multital_medias
    <Directory /home/adrien/multital_readme_html>
    Options FollowSymLinks
    Require all granted
    </Directory>
    <Directory /home/adrien/multital_medias>
    Require all granted
    </Directory>
CustomLog logs/multital-access_log combined
    ErrorLog logs/multital-error_log
RewriteEngine on
RewriteCond %{SERVER_NAME} =multital.inalco.fr [OR]
RewriteCond %{SERVER_NAME} =multital_wsgi
</VirtualHost>
And the https config file:
<IfModule mod_ssl.c>
<VirtualHost *:443>
    <Location /store>
    </Location>
    Require all granted
    </Directory>
    Require all granted
    </Directory>
    Require all granted
    </Directory>
ServerAlias multital.inalco.fr
SSLCertificateFile /etc/letsencrypt/live/multital.inalco.fr/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/multital.inalco.fr/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/multital.inalco.fr/chain.pem
</VirtualHost>
</IfModule>
Best regards
Hi and welcome to the LE community!
It seems that either:
  • port 443 is not actually listening
    check that with:
    netstat -pant | grep -i listen
  • port 443 is being blocked by firewall rule
Port 8443 is listening but HTTP forwards to HTTPS (port 443), so 443 must be used or don't forward the challenge requests and handle them in HTTP:
curl -Iki multital.inalco.fr
Date: Sun, 25 Oct 2020 22:50:10 GMT
Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16 mod_wsgi/3.4 Python/2.7.5
READERS: Get involved. Be heard. Do your part, it starts with: If you read something you like; then like it :heart: !
Hi and thanks for your quick answer.
The 443 seems to be listening (see below). How could I check if the problem comes from a firewall rule ?
$ netstat -pant | grep -i listen
(Pas d'infos lues pour "-p": geteuid()=1000 mais vous devez être root.)
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 ::1:5432 :::* LISTEN -
tcp6 0 0 :::443 :::* LISTEN
Do you have a firewall?
I had not noticed this before, and it is well worth mentioning now.
Port 80 is being served by APACHE:
curl -Iki http://multital.inalco.fr/
HTTP/1.1 200 OK
Date: Mon, 26 Oct 2020 08:07:14 GMT
Pragma: no-cache
Cache-Control: no-cache
Set-cookie: multital=ad1b90ca4e56e7c3a5229532365fa444e6ece781eJx1zE0KhDAMQOGrSNYypH+p8TIlrVUKo4J2J959Ou7dv+9dEMoEYwfRoBos+llZYwW9MCL7IZIj7Zki9B0ESSmfZ55CLWtuShEaYibjPqgda9eiuoSvbMv/OR+PSkeWWvbtTdn7B0seI7I=; Path=/
Content-Length: 153724
Content-Type: text/html; charset=utf-8
Port 8443 is being served by NGINX
curl -Iki https://multital.inalco.fr:8443/
HTTP/2 200
server: nginx
date: Mon, 26 Oct 2020 08:07:55 GMT
content-type: text/html; charset=UTF-8
x-frame-options: SAMEORIGIN
last-modified: Mon, 26 Oct 2020 08:07:55 GMT
set-cookie: PHPSESSID=47b8ef88f875194a91ca0567af133827; path=/
expires: Thu, 19 Nov 1981 08:52:00 GMT
cache-control: no-store, no-cache, must-revalidate
pragma: no-cache
strict-transport-security: max-age=31536000
x-content-type-options: nosniff
So the listener on port 443 may not be Apache...
Or there are some creative NAT rules / port forwarding going on...
Please show:
sudo ps -ef | grep -Ei 'apache|nginx'
I used apache for the cerbot/letsencrypt procedure. I don't have nginx installed on my server.
Below is the output of $ sudo ps -ef | grep -Ei 'apache|nginx'
apache 15940 15793 0 08:08 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 16622 15793 0 08:36 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 16623 15793 0 08:36 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 16625 15793 0 08:36 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 17163 15793 0 08:58 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 17776 15793 0 09:21 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 17777 15793 0 09:21 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 17778 15793 0 09:21 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 17779 15793 0 09:21 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
apache 17780 15793 0 09:21 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
adrien 24174 24146 0 13:32 pts/0 00:00:00 grep --color=auto -Ei apache|nginx
And yet nginx is still heard responding (as shown above) for port 8443:
HTTP/2 200
server: nginx
date: Mon, 26 Oct 2020 15:54:48 GMT
last-modified: Mon, 26 Oct 2020 15:54:48 GMT
set-cookie: PHPSESSID=1ac67110558e42def8cd4c435a223f45; path=/
pragma: no-cache
I repeat myself here:
Honestly, I can't say if there are some creative NAT rules / port forwarding going on. Do you have any idea of how I could check that ?
Hi @dsadoun
open that url - https://multital.inalco.fr:8443/
There is a pfsense with a warning:
Potential DNS Rebind attack detected, see http://en.wikipedia.org/wiki/DNS_rebinding
Try accessing the router by IP address instead of by hostname.
So your router interface answers.
