Received an expiration notice after successful renewal
Hi there,
My domain name is https://www.ieltsessaybank.com/
A couple of weeks ago, I opened Port 80 to allow http requests. I renewed SSL and then I closed Port 80. Today, I got a email saying that my certificate will expire in 9 days.
Is my certificate successfully renewed or not? Can I close Port 80? Thanks in advance!
Welcome to the community @Newer
No, your cert has not renewed. See your cert history here:
You show a dry-run test working so that is good. But, dry-run uses the test system and does not issue a cert. You need to run the renew without dry-run to get a cert.
Please just keep port 80 open. There's no sensible reason to close it. See Best Practice - Keep Port 80 Open - Let's Encrypt for more info.
Your system is behind a CDN:
Addresses: 2606:4700:20::681a:6a4
           2606:4700:20::681a:7a4
           2606:4700:20::ac43:44fe
           104.26.6.164
           104.26.7.164
           172.67.68.254
If the CDN is configured correctly, you shouldn't have to use port 80 at all on your system.
It was renewed today:
crt.sh | 7759926201
Yes, I renewed it after reading Post 2. Thanks for all of you.
