Certificate renewal does it need port 80 to be open
My domain is: testingweb.southeastasia.cloudapp.azure.com
I ran this command: sudo certbot renew --dry-run
sudo certbot renew
It produced this output: Attempting to renew cert (testingweb.southeastasia.cloudapp.azure.com) from
/etc/letsencrypt/renewal/testingweb.southeastasia.cloudapp.azure.com.conf produced an
unexpected error: HTTPSConnectionPool(host=‘acme-v02.api.letsencrypt.org’, port=443):
Max retries exceeded with url: /directory (Caused by SSLError(SSLError(1,
‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)). Skipping.
/etc/letsencrypt/live/testingweb.southeastasia.cloudapp.azure.com/fullchain.pem (failure)
The operating system my web server runs on is (include version): Ubantu 18.04
While incoming port 80 does need to be open if you are using the HTTP challenge, that doesn’t seem to be the cause of your error.
It looks like Certbot is unable to establish a connection to the Let’s Encrypt API server because it can’t verify its HTTPS certificate.
Is ca-certificates installed?
for automatic renewal of the certificate do we need to have port 80 open ,
the cron job to renew the certificate was failing once we enablde port 80 it renewed.
We have disabled port 80 now and dry run or sudo certbot renew both the commands are running fine
Getting confused with the behaviour
Thanks @_az for the reply
