RateLimited for a specific domain
when i try to create a new certificate from my domain i have:
Error: rateLimited :: There were too many requests of a given type :: Error creating new cert :: Too many certificates already issued for: my.domain
But i not create new certificate since several days.
So why I have this error ?
Thanks,
Yves
Hi Yves,
Was this the first attempt today ? or did you have a couple of failed attempts before it gave you a “rate limit” error ?
This is the first attempt today. This is why i wrote this question.
Was there anything in the logs ? and I assume you used your valid domain name rather than “my.domain”
Nothing special in the logs. The communications with the server are working well.
And yes i have a valid domain.
I have already generate some certs for other domains last week without errors.
I believe the limit is 10 certificates per second-level domain in 60 days. I’m not sure if I understood correctly, but I think you said you created certificates for this domain before - was it more than 10?
yeah maybe they ran into same problem i did Too many certificates already issued - rate limit? ?
Yes i have create 10 certificates has “subdomain” of my main domain.
So that is the problem.
Thanks all for you informations
