Here is the info from the Rate Limit page related to your limit
You can create a maximum of 10 Accounts per IP Address per 3 hours. You can create a maximum of 500 Accounts per IP Range within an IPv6 /48 per 3 hours. Hitting either account rate limit is very rare, and we recommend that large integrators prefer a design using one account for many customers. Exceeding these limits is reported with the error message too many registrations for this IP or too many registrations for this IP range.
Are you a system integrator managing large numbers of sites? Otherwise it looks like your dokku setup is very wrong. You should be storing Let's Encrypt data in persistent storage.
Please provide more info about your setup.
How do you register more than 10 times per 3 hours? Is everything in Dokku not stored on disk?
I don't follow. Why is this on your production server? Did you succesfully manage to implement Let's Encrypt using Dokku on your acceptance environment using the Let's Encrypt staging environment?
