Hello,
I am using certbot on my Raspberry Pi B (first generation) since a few years now, on Raspbian with Nginx.
Now, when trying to use certbot-auto, I am getting the following error:
sudo ./certbot-auto --version
Skipping bootstrap because certbot-auto is deprecated on this system.
./certbot-auto has insecure permissions!
To learn how to fix them, visit Certbot-auto deployment best practices
Your system is not supported by certbot-auto anymore.
Certbot cannot be installed.
Please visit https://certbot.eff.org/ to check for other alternatives.
I saw it was now needed to install snapd. However, snapd is not compatible with the old raspberry versions.
Is there an alternative to continue to use certbot without snapd ?
As additional information:
sudo certbot --version
certbot 0.28.0
