An unexpected error occurred: VersionConflict: (python-dateutil 1.5 (/usr/lib/python2.7/site-packages), Requirement.parse('python-dateutil>=2.1,<3.0.0')) Please see the logfile '/tmp/tmpxN84wO' for more details.
What’s the issue with this? We’re on CentOS 7. I think this is related to Python? How should I solve it? Thanks for any pointers.
Be careful with the --expand option, it may not give the desired results with the given input.
Even thou https://certbot.eff.org/docs/using.html says: --expand tells Certbot to update an existing certificate with a new certificate that contains all of the old domains and one or more additional new domains
It also says: With the --expand option, use the -d option to specify all existing domains and one or more new domains.
As I read that, if you leave any names out, the new cert may not include them.
